Do you save your used Motor Oil?
Discussion in 'Gen 2 Prius Main Forum' started by timtim2008, Jul 28, 2010.
  1. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    i save mine for my chain saw bar oil, .. and waste oil heater in the winter..
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
  3. Bababooey
    Bababooey Horse Toothed Jackass
    48
    Nassau County, NY
    No, I dump it down the sewer... only kidding! :D
  4. Patrick Wong
    18,200
    6,493
    The Walmart auto service center is another convenient used oil collection location.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I take mine to Advance Auto where they recycle it.
  6. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    Most auto parts stores and repair shops accept used motor oil. You can find locations here.
    I just soak mine up with a bald eagle.
  7. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    wow a bald eagle.
  8. timtim2008
    timtim2008 Member
    204
    22
    Alpharetta, GA
    anyone else?
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    A local garage here has a big recycling bin for it. I just pour it back into to an empty jug (usually from the previous oil change) and drop it off for recycling.
    I think most of the "recycled" oil around here just gets burnt which isn't really that great for the environment (I'm not 100% sure on that though). Anyway I'd rather see it get re-refined like the stuff they use to make Valvoline nextgen etc.
    As for re-using it for the chainsaw etc, I have done that in the past but these days I prefer to use clean oil for those misc lube jobs (bicycle chains etc). I pretty much always have one or two near empty jugs that have a little bit left, enough to use for that type of thing, so no need to bother with using the dirty used stuff.
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Not sure how using it in the chainsaw is better than dumping it down the sewer. It ends up in the environment either way.
    I use used vegetable oil in the chainsaw.
  11. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Along with used cooking oil taking from French Fries restaurants (sic Freedom Fries)...
    ... it is used for making Mascara and such feminine beauty products. ...ick...
    I used to think it was used for plastics.
  12. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I give my used oil to my buddy............ he has a used car :)
  13. Mendel Leisk
    40,582
    Canadian tire takes used oil. And filters. And emptied oil bottles.
    Mohawk Gas used to take used oil. One advantage with them: you just dumped your oil into their tank; less containers to deal with.
  14. darelldd
    6,059
    389
    Northern CA
    Is now a good time to be annoying and mention that EVs don't require oil changes? I change the oil so rarely in the Prius that I forget how to do it each time! But to answer the question - I collect it, but don't "save" it. It is taken to the recycle center where they take the filters as well.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    You're smug now, but wait until you have a bucket of old electrons to recycle. Who do you think will take them? You are going to end up dumping them down the drain just like all of the other sparkies.
    Tom
  16. darelldd
    6,059
    389
    Northern CA
    Oh heck no. I'll just transfuse the electron soup with this new process:
    MIT Students Develop Liquid Fuel for Electric Cars – Gas 2.0
  17. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I just calculated that I use approximately 170L of fuel for each 1L of engine oil that I use.
    Each OCI (3.5L oil) : 14000 km = 588L of fuel (@4.2L/100km)
    From that perspective I'm pretty sure that recycling engine oil is more about being sure that it is responsibly disposed of rather than doing much to conserve oil.
    BTW. That's doing fairly long (8500 to 9000 mile) drain intervals on good quality oil. I guess for a lot of people doing shorter intervals the fuel to oil usage ratio would be a lot lower.
  18. darelldd
    6,059
    389
    Northern CA
    Proper disposal is certainly the most important reason. Folks used to just dump it on the ground in down a storm drain. Now that we've some more creative uses for the re-refined oil, there are several great reasons to recycle.
  19. Mendel Leisk
    40,582
    I agree. Every time I hear someone extoll the longer service intervals as a way to conserve oil I get exasperated: engine oil consumption is insignificant compared to gasoline consumption, regardless of interval, say 5000 mi vs 10000 mi.
  20. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    "I just soak mine up with a bald eagle."
    Choked on my breakfast, thank you!
