Do You Use "B" Mode Much?
Discussion in 'Prius c Main Forum' started by Lukey51, Feb 5, 2020.
  1. Lukey51
    Lukey51 Active Member
    203
    108
    TN
    I do. Most cars I've owned have had 5 speed trannys so I've liked to downshift to help slow me down before red lights, stops signs, etc. to save on brakes. With the B mode, I find that it works well to downshift and slow me down without touching the brake pedal. I love the B mode in my Prius C. And if the light turns green before I come to s stop I just nudge it back into D mode and proceed.
    John in Vermont likes this.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Using B mode may save some wear on your brakes, but even that is questionable, since the car will use regenerative braking rather than mechanical brakes for all but panic stops or where your speed is less than 7 mph. In those circumstances, B mode will not slow the car sufficiently and you will be forced to step on the brake pedal anyway. These cars are famous for preserving brake linings, even just driving them normally, because of the regenerative braking using MG2 to provide stopping power rather than mechanical brakes. Our Gen 2 did not require new brake pads until it had reached ~200k miles and I think that is fairly typical.
    The area where you will notice a difference in using B mode frequently is in your MPG. Instead of allowing MG2 to recapture kinetic energy as your car slows, you are forcing that energy back through the Internal Combustion Engine, where it is of no benefit. Although there is no gasoline being used when your engine revs to slow you down in B mode, there is still a cost, that being that your HV battery is not being charged as it could have been by stepping on the brake pedal and using regenerative braking. I believe most of the members here would only recommend using B mode on a long downhill ride, where the battery will reach a full charge before you reach the bottom of the hill. Under those circumstances, the car will cease using regenerative braking and stepping on the brake pedal will apply mechanical brakes only, so that using B mode in that situation will save your brake pads some wear.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    @davecook89t
    wow, well said!
    @Lukey51
    yeah no reason to use it all the time, but hey your car...drive like you wanna
    I use "b" mode in my "c" like a couple times a year.
    I used it a few days ago when I had a tailgator behind me for shits and giggles
    Chipperson, davecook89t and Lukey51 like this.
  4. Lukey51
    203
    108
    TN
    Hahahahaha. That sounds like something I'd do. I don't like "tailgators".
    I don't tail gate and I don't appreciate it being done to me. Many people tail gate around here and then wonder why there are sometimes multi car pileups.
    jerrymildred and davecook89t like this.
  5. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    If you can use your brake pedal gently for at least 7 seconds before stopping, you'll get the best energy recovery into the battery.
    Remember, a discharged battery is the capacity of your electric brakes. Once the battery is full, you no longer have electric brakes.
    B mode is a way to tell the car to fill the battery more slowly and also divert torque into traditional engine-braking. Advantage: once the battery is full, the car automatically diverts all torque into the engine without any further input from the driver. Safer for long mountain descents.
    jwl2000, George W, fuzzy1 and 2 others like this.
  6. Lukey51
    203
    108
    TN
    OK, so I'll use B mode rarely.
    This shows how new I am to the Prius.
    I get most of my info from forums like this. With ADHD, I'm not much of a reader.
    The way my life has been, I have to absorb information at any speed I can.
    I can't make myself sit down and read and soak up information but if I want to learn something bad enough, sooner or later I will.
    Thanks for explaining this. It seems better to use the brakes. I never ride my foot on the brakes anyway so that should be fine.
    davecook89t likes this.
  7. Lukey51
    203
    108
    TN
    My battery never seems to get totally full but it gets up to "mostly" full. Is that normal?
    Maybe I should pay more attention to what's going on in the system when I drive by selecting another display mode.
    I haven't used the B mode too much but probably more often than I should have used it, mostly just the last few days.
  8. Lukey51
    203
    108
    TN
    It sounds somewhat confusing but I'll rarely use B mode any more.
    I'll also see what I can learn from the manual and youtube.
    Plus this forum has some files I'll check out.
    TGrracie and davecook89t like this.
  9. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    The display on the dash is lying. Even when it says full, the battery is really at about 80%. When the display says it is empty, the battery is at about 40%. This is because the battery lasts far longer when you never use the top or bottom extremes.
    The way I see it, the gauge is lying and generally distracting. And I paid good money for automation. So I never look at the thing. We set ours up to show the "simple" display which is just a big fuel gauge, clock, outside temp and average MPG.
    You didn't hurt your car at all by using B mode. No gears ever decouple or reconnect. The computers always prevent harm to the battery.
    Slowing down in any car converts your kinetic energy into some other form.
    In a Prius in D mode, you are converting it into electricity for the battery and heat at the friction brakes.
    In a Prius in B mode, you are converting it into less electricity for the battery, heat at the friction brakes and noise/compressed air in the engine.
    Green for energy that is recovered
    Red for energy that is wasted forever.
    So you aren't hurting anything, you're just deciding if you want one total-loss energy drain or two. Sometimes you need two to stop the thing.
  10. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    6 out of the 8 bars is where the battery is considered normal.
    Mine will sit there "most" of the time.
    When I keep my gas pedal in the "ev" range I can drive in electric and battery may go down 1 or more bars
    When I stop I will keep my brake in the "regen" range to recoup most of the charging battery may go up one or more.
    I will teeter best regen and best ev use to get best mpg and best coasting to hyper mile.
    It takes some practice but you can become a champ and it will be second nature after a while.
    There are some "tips" videos on hypermiling and should watch a few to see best way to
    get most out of natural inertia and hills, and braking and such.
    let me see if i can find a good one....
  11. Lukey51
    203
    108
    TN
    This seems contradicting although I may have read it wrong.
    I used to make trips to Asheville NC sometimes that's an hour South of here. I'd pass over a big mountain range and I used to use lower gears on my other cars to keep my speed from increasing to over the speed limit. So if I took my Prius C there, I should use B mode as I did with my other cars to help limit my speed? I thought you said the B mode doesn't charge the battery, that only manual braking charges it?
  12. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    Use B going down that hill.
    Yes, B mode charges the battery less- because what happens if the battery fills up when you are only halfway down the hill? Any pressure on the brake pedal there would trigger the friction brakes without you necessarily realizing it, since the computer substitutes them in automatically. Result: overheated brakes halfway down the mountain. Bad.
    B mode tells the computer to recover a little power into the battery and also to seamlessly dump energy into the engine once the battery is full. That way your friction brakes stay cold and ready for service.
    In a nutshell, any time you want to prevent a mountain road runaway is when you would want your Prius in B mode.
    #12 Leadfoot J. McCoalroller, Feb 6, 2020
  13. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    here is a quick vid. most tips on point.
    it is basically saying how all people should drive to get higher mpg, and
    with the prius it will just give you more mpg
    The flooring of the gas, and slamming on the brakes is how most people drive.
    Lukey51, davecook89t and Raytheeagle like this.
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    I really disagree with the advice he gives at the end of this video about turning your vehicle off while sitting at a red light.
    IMO Prius/Hybrids are very specifically designed to turn off the ICE when possible BUT they constantly allow for on demand instant movement if needed.
    Standard ICE vehicles do NOT do this.
    I've seen accidents happen at intersections involving cars that were at complete stops. Point is....you never know when you might want or need to move-instantly or on demand. SO IMO with a regular ICE vehicle sitting at a red light with your engine turned off, is dangerous.
    It's NOT worth it.
    Might even be illegal.
  15. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    /\ /\ /\ yeah that would be stupid for an ICE driver to do that,
    but yes Prius does it well.
    Then you have the start/stop ICE which I think is just weird.
    I have been seeing (hearing) those around a lot in the past 6 mo
    Lukey51 likes this.
  16. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    *shrug* I think most hypermiling techniques are incompatible with or unfriendly towards public traffic, but to each their own.
    We just buckle up and drive, trusting the computer to save fuel. It's been working.
    Royston.K, Toyo_Tom and Lukey51 like this.
  17. The Electric Me
    9,083
    5,798
    Having owned a Prius and then gone back to a ICE.
    I would say the Prius does teach you how to be an economical driver.
    I don't think you have to be too Draconian in application of any techniques. And as I point out above, there are things a Hybrid does by design that ICE shouldn't or can not do.
    But I also have found that just casual application of some of the "common sense" techniques, such as looking ahead, using momentum, and avoiding hard stops and jack-rabbit starts can really help boost MPG, with even a regular ICE vehicle.
  18. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I rarely use it.
    I think post 11 offers the best advice, use on long downhills, such as highway I-5 into the Los Angeles Calif area.
    Not sure if I would say B mode enhances driving fun if "racing" around.
    Engine braking/ compression can be a benefit, but again I rarely use it.
    FWIW Nascar Richard Petty quote, "Brake parts cost less than engine parts".
    Lukey51 likes this.
  19. The Electric Me
    9,083
    5,798
    I suppose as long at there is a Prius Chat, and as long as Prius has a "B" mode the re-occuring theme of people thinking they have found a new, better, or additional way of using "B" mode to advantage is going to keep coming up, over and over.
    IMO...
    Just use "B" mode as the owners manual recommends. Which is on longer downhill descents.
    THAT'S IT.
    You own a very specialized vehicle now. With an mechanical and computerized HSD system designed to be working in concert.
    You don't own a manual stick shift vehicle. In some ways "B" might mimic the "feel" of downshifting. But it's NOT downshifting.
    JUST DRIVE IT.
    If you want to downshift? And make those human driving input decisions? You're driving the wrong vehicle.
    Toyota has gone to a lot of lengths to over decades design both the mechanical and the computerized side of the HSD system. WHY people continually think they know better than the system?
    IMO you don't need, nor should you be using "B" mode for ANYTHING beyond what the owners manual recommends.
    Lukey51 and davecook89t like this.
  20. bisco
    49,498
