does 2012 center armrest fit in 2011?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by megaloman, Aug 28, 2012.
  1. megaloman
    megaloman New Member
    austin
    Does anyone know whether the 2012 center armrest fits in the 2011 prius?
    If so, can I just buy the flip-up part? Or would I have to replace the entire assembly? Or something in between?
    Best regards,
    mega
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I believe u would have to buy the whole assembly.
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    what's different?
    Never mind - I just googled images - much better!
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Lol
  5. megaloman
    austin
    Yeah, you are right. I found two good images for comparison in this thread:
    For Sale - Toyota Prius 2010+ - Brand New Clazzio Full PVC Seat Covers Black | PriusChat
    I guess I was hoping that whole top part would just come off and fit into place, but that doesn't seem the case.
    I agree with several other postings, the 2010-2011 is an unbelievably impractical design. There are two problems.
    1. With armrest in the "open/cupholder position" and a kid in the back center, I always end up with footprints on my armrest.
    2. If you are using the charger or aux input, you can't close the console unless your device remains in the console. There is literally no crack or hole for routing the cable through, once the lid is closed.
    To solve #1, it sounds like I have to follow this example:
    I wasn't able to find any aftermarket armrests that resemble the 2012, but I'd definitely like to find one to solve #2 and just the general problem of having more exposed cupholders to put my cups and phone in.
  6. megaloman
    austin
  7. El Nino
    El Nino Member
    210
    Michigan
    I'm in the process of modify a 2011 to a 2012 armrest and cupholder. The cost from the dealer to replace the whole center unit is $600. The cupholder alone is $120 and you need to cut/dremel some parts. You leave it engaged mid way back and cut off the excess that hangs over. I have a katzkin cover to go ontop of the newly cut top so Im hoping for the best. Will post a thread when done.
    E
