Does a bad brake booster damage the engine?
Discussion in 'Gen 3 Prius Technical Discussion' started by bk2049, Feb 11, 2025.
  1. bk2049
    bk2049 Junior Member
    63
    Ohio
    My 2010 (engine replaced a few years ago) has had brake booster issues for a while. Lots of clicking and booster "purr" more often than it used to. One mechanic told me that not replacing the booster will damage the engine. Another said there's no connection. I've been delaying replacing the booster because of the age of the car and hesitation about whether it's worth the cost but if it's hurting the engine I might make it a priority.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    No it won't hurt the engine. The brake booster is usually ok even with frequent operation at least until it codes. At that point there is a limited grace period until the brake booster could hurt you through poor braking performance.
    bk2049 and Brian1954 like this.
  3. bk2049
    63
    Ohio
    Thanks rjparker. Appreciate your help in the past, too. Hope all is well!
  4. ChapmanF
    17,349
    Damage to the engine is indirect, say if the brakes don't stop the car and there's something jaggy and hard in front of it that damages the engine. :)
    bk2049 likes this.
