Does a power inverter connected to the 12v battery drain the battery when it's turned OFF?
Discussion in 'Gen 2 Prius Audio and Electronics' started by wbs887700, Feb 12, 2021.
  1. wbs887700
    wbs887700 Junior Member
    74
    I keep having to jump start my 2006 Prius and I can't tell if I need a new 12 volt battery, or if the inverter is draining it while it's turned off AND the Prius is off.
    This picture is my 1500 watt pure sine inverter, I drilled holes for the wires and bolted it to the 12-volt battery.
  2. ChapmanF
    18,220
    Depends entirely on the inverter. I once had one that did, which was annoying. I had to add a separate relay in the wiring to the battery to really turn it off. Now I have one that doesn't.
    donbright and wbs887700 like this.
  3. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    A cut off on the line in would provide diagnosis and a fix. Did you fuse it down at the battery?
  4. ChapmanF
    18,220
    I've been using a Xantrex Prowatt SW since, which I can vouch is genuinely off when it's off. It's a lot more convenient to just have an inverter with a real "off" than to have to fuss with finding and installing a high-current relay or cutoff.
  5. wbs887700
    74
    My inverter does have an off switch. Does that mean it definitely turns it off?
  6. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    It doesn't mean much. Every inverter manufacturer does it their own way. Some have real off switches that completely interrupt all power. Others just put the inverter into a sleep mode which can still draw some power from the battery.
    You have to read the manual, contact the manufacturer or break out an ammeter and do a real live test.
    Given how small the Prius 12v battery is, it doesn't take much "non-Ready-mode" use to get into trouble.
  7. ChapmanF
    18,220
    The one I had earlier defined "off" as "please chase the outer segments of your LED display around in an animated circle for entertainment." (n)
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    AND......is nobody going to suggest getting the 12 V battery tested ?
    And the charging voltage ?
    Except me ??
    I think the simple fact that an inverter is in use might mean that the battery has been "abused" and is now worn out.
    And I agree that the inverter OFF switch might not turn it completely OFF; a test is necessary.
