Does Air Conditioner have daylight sensor?
Discussion in 'Gen 2 Prius Main Forum' started by charlesp210, Feb 27, 2008.
  1. charlesp210
    charlesp210 New Member
    I recall my first (2001) Prius Air Conditioner had a daylight sensor. It didn't work perfectly, but it was clear that it was doing something. (I can't remember exactly how well it worked now, maybe it overcompensated.) I read about it too.
    It's not so obvious my 2006 Prius A/C has a daylight sensor. I always have to manually bump down the temperature in daylight, then bump it up at night time. Consistently. Call me thin skinned, but I like to be comfortable (and I live in Texas). Particularly on a bright sunny day, it can be cool outside, but with the sun blasting on me I want A/C. Fortunately, with Option Package 7, I have the temperature controls on the steering wheel.
    But could it be that 2004-2008 Prius A/C has a daylight sensor, and mine isn't working, or isn't adjusted properly?
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, there is a daylight (aka solar) sensor located at the base of the windshield at the drivers side corner.
  3. Grunthos
    Grunthos Senior Azgoth Poetmaster
    81
    Minneapolis, MN
    I've been wondering why there was a light sensor there. I always assumed that Prii in other countries had automatic headlights, or something.
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, there is actually two locations, but on US cars one is blank. That is for Auto Headlights which we don't get. There are references to it in the owners manual and some of the repair manuals.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Welcome to PriusChat, charlesp210! The Auto setting on the air conditioning system works pretty well at keeping the cabin air temperature at what you set, but it can't compensate for direct solar heating on your skin. The glass on the new Prius has a high iron content so it tends to reflect infrared radiation to keep the cabin cool, but Texas sun is still hot.
  6. Tideland Prius
    16,127
    It has a temperature and humidity sensor but it doesn't have a solar sensor (say.. like an Acura TL) so it doesn't automatically direct more (cool) air to the side of the car facing the sun.
  7. Bill Merchant
    4,096
    81
    TP, the North American Prius DOES have a solar sensor. Take a look at dogfriend's pdf. It may not work like Honda's, but it exists and cools more when the sun shines.
  8. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Yeah, there's a sensor, and it works fairly well. Except when the Pennsylvania inspection stickers casts a shadow across it. When I get my Prius inspected, I have to ask them to mount the stickers a little higher so they don't block the sensor. Otherwise, I have to keep bumping the AC up and down depending on which direction the car is facing. Head north and the sensor is in a shadow and the AC turns down. Head south and the AC starts blasting out cold air.
  9. darelldd
    6,057
    389
    Northern CA
    Marlin - you've just explained something that truly has mystified me all these days. I have had the North-South experience several times, and could not figure out what was going on!
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Yep, my Prius has two bumps: one for the auto headlights, and one for the climate control
  11. Flying White Dutchman
    4,374
    313
    ok
    my prius only got 1
    maybe that one can be used by a canbus to operate auto headlight?
  12. Tideland Prius
    16,127
    Yeah I know, that's what I called the temperature sensor lol.
    The "solar" sensor (and I guess you'll have to come up with your own name since you already used solar sensor) that I'm referring to in the Acura TL can actually sense which side is facing the sun and can direct more cold air (probably requires dual-zone automatic climate control) to that side of the car to maintain the desired temperature rather than having to make the passenger lower the temperature manually.
    Hmm.. maybe I can call it the "sun" sensor instead?
  13. Fibb222
    Fibb222 New Member
    1,499
    99
    Mine too, but only in Canada, eh.
  14. charlesp210
    Thanks! Well now I know why my sunlight sensor wasn't working very well, I have three stickers right above it !!!
    I'm going to be migrating the stickers upward, but it will take awhile because they have to be in a particular order, but I'll move each one up when I get the new one, if I can.
    Seems to me they could have picked a better spot for the sensor than on the left side, where often US state laws require you to place the registration and inspection stickers.
  15. Tideland Prius
    16,127
    It'll be on the passenger side on RHD cars ;)
  16. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    It is equipped with a photo-diode and detects the sunlight.
    It can't be a temperature sensor.
    Ken@Japan
  17. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Japanese RHD Prius comes with the solar sensor on the right, driver side.
    Ken@Japan
  18. Tideland Prius
    16,127
    So yours is slightly more sophisticated than ours?
    Cause I know for sure it won't blow colder air to one side of the car if that side is facing the sun (we don't even have dual zone)
  19. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Um...
    NA LHD Prius comes with the solar sensor on the left, driver side.
    JP RHD Prius comes with the solar sensor on the right, driver side.
    Why do you think JP Prius is more sophisticated than NA's?
    Ken@Japan
  20. Tideland Prius
    16,127
    ok never mind. You guys don't know what I'm talking about so I'll just agree and say yes you're right. My words are being jumbled up. I know what you guys are talking about and my choice of words are probably not good choices cause both of you got confused :(.
