Does anyone know the diameter of the front sway bar?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ilovegirls, Jan 25, 2021.
  1. ilovegirls
    ilovegirls Member
    177
    San Diego
    I need to replace the front sway bar bushings but I need the diameter. Looking to use energy suspension bushings.
  2. Mendel Leisk
    40,586
    You want to know the diameter of what you have? Check with a caliper?
  3. ghost2255
    ghost2255 Junior Member
    Poland
    24mm
    ilovegirls likes this.
  4. ilovegirls
    ilovegirls Member
    177
    San Diego
    I don't have a caliper and I was hoping someone would know right off hand.
  5. ilovegirls
    ilovegirls Member
    177
    San Diego
    Thank you
  6. Mendel Leisk
    40,586
    A cheap one is maybe $5~10, more than adequate for rough measure like round bar OD. Or get a decent dial gauge style for $40~50, you won’t regret it. Avoid digital; they CAN eat batteries. The high end ones might be ok, but who knows.
  7. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    they W I L L eat batteries /
  8. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    There is a formula, which I don't know, where you can wrap a piece of paper around it, mark it,
    then measure the length of it and apply the formula to get the circumference.
    You could also us a cresent wrench over it, tighten it and then measure the gap.
  9. Mendel Leisk
    40,586
    Divide measured length (circumference) by 3.14159 (roughly Pi) will give you diameter.
    Attila Fekete likes this.
