Does anyone know what it could be?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jose Junqueira, Jan 29, 2025.
  1. Jose Junqueira
    Jose Junqueira New Member
    6530 Virginia Pkwy, McKinney, TX
    Hi guys,
    I have a 2006 Prius, before I only had error C1310, when I changed the 12v battery. Then error C1310 returned and now error C1241 appeared.
    I thought it could be a hybrid battery, as the panel that shows the operation of the hybrid battery is sometimes fully charged, and very quickly shows it completely discharged.
    Has anyone been through this?
  2. JC91006
    16,651
    8,501
    C1241 is not a real problem. But your hybrid battery meter going from full to empty really quick is a problem with the hybrid battery getting really weak. So it might be time to recondition the battery or change it for a new one.
    Jose Junqueira likes this.
  3. ChapmanF
    17,180
    I'm not sure what isn't 'real' about C1241. It's a problem with 12-volt power reaching the brake ECU. Sometimes it affects only the brake ECU (say, a damaged power wire serving the ECU), and sometimes it hints at a problem affecting multiple systems (say, very low voltage from the 12-volt battery).
    C1310 is a code that isn't for a real brake problem: it is reported by the brake ECU, but it is set because the hybrid-vehicle control ECU has a problem to report and the brake ECU heard about it. The best way to get the full story is to use a scan tool that is able to get the trouble code(s) from the HV control ECU.
  4. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    Go play with your 12 volt system Make sure you're 12 volt actually has 12 volts with some juice behind it to back it up The AH part of the battery we're talking the 12 volt here no 12 volts lots of lights lots of communication problems lots of funny business intermittent 12 volts same thing an AGM battery that's worth it salt is going to be generally showing 12.3 to 12.7 volts at rest You get lower than that and you are way off and things will stop communicating and communicator radically and screw up the can bus so maybe not have that going on once that is established and cleared then you can move forward with a tweaky 12 volt system You're never going to get much of anywhere.
  5. bisco
    51,011
    It is sometimes corrosion at the ecu connection, and yes, the hybrid battery is going south
