Does anyone know where the fuse is located for the odometer?
Discussion in 'Gen 4 Prius Technical Discussion' started by Priipriii, May 7, 2023.
Tags:
  1. Priipriii
    Priipriii Member
    213
    Im trying to test something out, just curious if anyone knew its location in the fuse box
  2. Doug McC
    Doug McC Senior Member
    1,006
    377
    Midwest
    2022 Prius
    You are posting in the Gen 4 section (just saying since your info shows a 2013). And the Odometer is a function of the ECU not a separate entity.
  3. ChapmanF
    15,703
    Specifically, I think the odometer value is retained in the combination meter assembly.
    You could check the wiring diagram for which fuses supply that.
    Toyota Service Information and Where To Find It | PriusChat
    (If I remember right, in at least one generation, it's got a kind of interesting arrangement where two different fused circuits feed it, and it contains a diode so one can't backfeed the other.)
  4. Priipriii
    Priipriii Member
    213
    Yes, im aware. I have two priuses actually. I am not sure if gen 4 is the same as the gen 3 when it comes to the instrument panel wiring. I am going to take a guess and say the odometer fuse is also the same fuse connected to the rest of the panel.
    Doug McC likes this.
