Does anyone know *why* the Prius beeps in reverse?
Discussion in 'Gen 2 Prius Technical Discussion' started by teyde, Sep 16, 2007.
  1. teyde
    teyde New Member
    17
    Hi. I have seen numerous posts where people ask how to turn off the reverse beep, and equally many to describe how.
    But does anyone actually know why Toyota decided to add that sound? So far I have only seen speculations.
    And why can't Prii owners outside of North America turn off their beeps?
  2. judymcfarland
    judymcfarland Queen of Moral Indignation
    578
    Glendale, WI
    I don't mind the beep because then I KNOW I am in reverse - at least once during the first week I thought I was in reverse & wasn't. Fortunately no harm done. Yes, it can be a little annoying sometimes, but I use it to remind me that I really am in that gear. I wish the beep were audible outside the car, too, as a warning to others that don't notice the back-up lights.
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(Grandma Judy @ Sep 16 2007, 08:42 PM) [snapback]513469[/snapback]</div>
    You can install a beeper attached to the wires that turn on the back-up lights in the taillights. It's faint but can be heard both outside and inside the car. I did this and then disabled the regular beep as it was very annoying having two.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It beeps in reverse because of the non-standard transmission making it easy to shift into the wrong gear. Also it was easy to implement with the existing electronics. I have no idea why it can't be turned off elsewhere, although I always suspect legal issues in a situation like this.
    Tom
  5. Tideland Prius
    16,066
    <div class='quotetop'>QUOTE(Thomas Eyde @ Sep 16 2007, 06:32 PM) [snapback]513464[/snapback]</div>
    Because the shifter returns to its position, there isn't a "double check" for those that aren't used to looking at the dashboard for the shift indicator, hence the reverse beep.
    As for the disabling function, I have no idea.
  6. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    <div class='quotetop'>QUOTE(Godiva @ Sep 16 2007, 08:52 PM) [snapback]513473[/snapback]</div>
    Great idea! Did you post details on how you did this elsewhere (can you provide a link to the thread?)? Thanks.
  7. teyde
    teyde New Member
    17
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 17 2007, 05:41 AM) [snapback]513511[/snapback]</div>
    Thanks. This is the usual answer presented elsewhere, too. Is this the official reason, too?
    This reasoning makes sense to some people, while others, like me, thinks this is utter nonsense. Being in the nonsense category, it's frustrating to know I can't disable the beep when my Prius finally arrives in a month.
    For anyone interested, I think the logic is flawed. However, I can see one good reason for a warning: There is nothing mechanical that stops me from putting the car in reverse. But wouldn't it suffice to issue the warning when we hold the shifter in the R-position, and turn it off when we release it?
  8. vtie
    vtie New Member
    436
    Gent, Belgium
    I don't understand the logic behind this. First, they make this tiny shifter that is so easy to put in reverse and that doesn't show you the current position. And then, they make this very annoying sound to remind you that you are in reverse?
    Personally, I would prefer a shifter that does show its position (and perhaps some more force feedback), without the annoying sound.
  9. silver-machine
    silver-machine New Member
    51
    Sheffield UK
    I know this is unpopular, but I respect the reverse beep.
    It is a useful reminder of the quiet, and smooth behaviour of the car. And yes once I put it into reverse by mistake and it prompted me that I had before I backed into the bollard behind.
  10. teyde
    teyde New Member
    17
    <div class='quotetop'>QUOTE(silver-machine @ Sep 17 2007, 11:42 AM) [snapback]513592[/snapback]</div>
    I can see that. But I think the beep is solving the wrong problem, and that coming from Toyota is quiet surprising. The shifter should have been designed to make this mistake harder or impossible to do.
  11. skandale
    skandale Member
    101
    I currently have a Peugeot 1007 with the3 2Tronic semi-automatic gearbox. It's a manual gearbox with electronic clutch and electronic gear shift. All i have is a little stick in the centre console and paddles at the wheel. It's kind of like the same as BMW's SMG gearbox, but muuuuuch slower and simpler.
    The gear shifter always returns to it's neutral position and the only indicators of your shifting to reverse is one small beep and a R on the instrumentation. You really should know that you put your car in reverse.
    As for remembering that you actually have your Prius in reverse, when you ease up in the brake pedal, the car starts to pull backwards. This should give you a hint. I NEVER let go from the brake and floor the throttle, so I would never jump meters backwards if I should fail to change to Drive.
    I believe that the beeps would make more sense on the outside than on the inside.
    -Stein
  12. patsparks
    10,664
    567
    Adelaide South Australia
    The beeper in reverse reminds me that the car may be silent when reversing and therefore audibly invisible to pedestrians, therefore I must be extra vigilant when reversing. Maybe that is why the beep is there. It bothered me at first but now I like it.
  13. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  14. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I like the beep, it reminds me where I am going.
  15. vtie
    vtie New Member
    436
    Gent, Belgium
    <div class='quotetop'>QUOTE(catgic @ Sep 17 2007, 02:36 PM) [snapback]513618[/snapback]</div>
    Why didn't they make a shift lever that does indicate what position it is on in the first place? Shouldn't be too hard. It doesn't make sense to me that they compensate an imperfect design with an annoying beep signal...
    <div class='quotetop'>QUOTE(Michgal007 @ Sep 17 2007, 02:47 PM) [snapback]513622[/snapback]</div>
    I can imagine that some people like it. Others, like me, don't like it. In 21th century cars, there is a nice solution this dilemma: make it an option you can disable or enable.
    If they really want, they can add a security warning that you have to acknowledge before disabling it.
  16. qbee42
    18,058
    3,073
    Northern Michigan
    <div class='quotetop'>QUOTE(Michgal007 @ Sep 17 2007, 08:47 AM) [snapback]513622[/snapback]</div>
    You need a beeper to warn you about hills! :p
    Tom
  17. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    <div class='quotetop'>QUOTE(Thomas Eyde @ Sep 16 2007, 07:32 PM) [snapback]513464[/snapback]</div>
    To provide a recurring topic on Prius forums?
  18. MHarris
    MHarris New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Sep 16 2007, 10:41 PM) [snapback]513511[/snapback]</div>
    I saw a completely self-contained backup warning beeper at the dealers a few weeks ago. It has it's own battery, and is activated by a photosensitive element (picking up the backup lights). It sticks on, and is cheap (probably in every sense of the word), but clever.
    MH
  19. acdii
    acdii Active Member
    1,124
    131
    If anyone has noticed. The ICE will not run in reverse, unless the battery is very low, or the car was just turned on. The ICE has no means of powering the car in reverse, it is truly electric only. If your car is warmed up and you have it in reverse by mistake, which I have done a couple times, dont ask how, it is a way of alerting you that it is in reverse. Most people pull IN to a parking place(reason I wound up in reverse), so if you forget to press park, you roll forward against the stops. If you previously drove a regular shift style car where you moved the lever into park, and move the shifter into reverse in this car, you know you dont have it in park. Thats my take on it.
  20. teyde
    teyde New Member
    17
    <div class='quotetop'>QUOTE(RedRockPrius @ Sep 17 2007, 05:09 PM) [snapback]513695[/snapback]</div>
    Yes, I know. I am terribly sorry about that. My intention was not to start yet another thread on how to disable it or how to install an outside beeper.
    It's just that there are so many suggestions on why the beep is there, but no explanation on why Toyota added the feature in the first place. There are so many things they got right in this car, so why they made this bummer is a mystery to me.
    <div class='quotetop'>QUOTE(ACD @ Sep 17 2007, 07:48 PM) [snapback]513793[/snapback]</div>
    If I forget to press 'Park', does it matter which way the car will roll? I will bump into something, anyway. If I stop while in 'Drive', I get no warning. while in 'Reverse' I do. I fail to see the logic here.
    I have read "The Prius That Shook The World", which tells the tale about the development of the car. Funny it doesn't mention the beep.
