Does atf change cause a temporary drop on mpg?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by mark27lim, Apr 18, 2018.
  1. mark27lim
    mark27lim Active Member
    108
    103
    singapore
    Just wondering cos mine was done at 40k km mark by the dealer. it feels as though mpg has dropped slightly. used to be able to hit 36km/l on the work commute on occasion. after the change struggled to hit >30. now 3 months later it’s around 30-33km/l. we’re at the 48k km mark. hopefully it keeps improving. i didn’t check what atf was used, hoping that it was toyota ws and not a cheap aftermarket.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    atf? - do you mean Automatic transmission fluid? It wouldn't have been changed at 40k km, only engine oil.
    I'd be going back to the dealer and advising that your km/l has got much worse - and asking if something they serviced might have caused it. Have you checked tyre pressure - it's the only thing they should have done which, if done incorrectly should cause your l/100 to go bad.
    RCO likes this.
  3. mark27lim
    108
    103
    singapore
    thanks Alan, yes it was auto trans fluid and done when i brought it in for routine oil change. i think the workshop scheduled it at this odd 40k just so that they can earn extra on the markup and labor. unfortunately my car is a jdm import so the local toyota here will refuse to service it so that people are forced to buy the car (official export version) from them instead. i have no choice but to get my warranty and routine service from a 3rd party workshop instead. thus they can claim that if i do not follow their schedule it will void our warranty agreement.
    tyres are fine. i keep them in the high 280kpas as reported by the tpms
    alanclarkeau likes this.
  4. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    So toyota didn't change the atf, a third party did?
    If so, what atf did they use, sounds like if it wasn't a toyota shop, they used something other then the recommended atf which would explain the loss of mpg.
    RCO and Tande like this.
  5. mark27lim
    108
    103
    singapore
    went back and checked the receipt. apparently they used 3.5l of Aisin AFW+ .
    spec sheet is here http://www.exedy.com.au/assets/file/AISIN_Fully_Synthetic_AFW_Multi_Product_Datasheet.pdf and promotion poster is here http://www.aisinaftermarket.jp/en/products/atf/images/atf_a2_CFEx_AFW+.pdf
    did some wikipedia on this company. part owned by Toyota, they apparently were the developer of the gen1 and gen2 prius transmissions !?!
    i think this atf checks out for the prius. afw+ is claimed compatible for toyota ws-the prius atf. the poster also recommends 40k or 2 years change which explains the odd schedule. i think my drop in mpg might also be due to other factors as well-like a change in commute route all else being equal.
    Mendel Leisk and RCO like this.
  6. bisco
    49,500
    track your fuel efficiency by the tank full, calculated at the pump. it is much easier to see positive and negative trends, than just watching the gauge whilst driving in varied conditions.
  7. mark27lim
    108
    103
    singapore
    just wish to update that i’m getting back to my normal mpg performance. about 4 months after the atf change. phew s!
