Does bad wheel hub damages ABS pump
Discussion in 'Gen 2 Prius Main Forum' started by Mikash Kumar, Nov 22, 2022.
  1. Mikash Kumar
    Mikash Kumar New Member
    Fiji
    Hello, Im from Fiji Islands and we don't have an expert, Prius Mechanic. Recently my 2008 Model prius had the ABS pump problem, therefore i got it replaced now the mechanic says that the rear wheel hub is also damaged. i believe he is correct since i can hear the humming noise, but he tells me that this could harm the ABS pump. please if anyone could let me know if this statement is true?
  2. Tombukt2
    Tombukt2 Senior Member
    9,235
    1,618
    Durham NC
    I don't see how the humming of a bad or failing rear wheel bearing or any hub bearing could cause your ABS pump to fail that is as ridiculous as it sounds now if the hub bearing failed and the wheel fell off and it damaged some of the hydraulics and the pump continued to run and then died and then and then and then well then technically letting the bearing go caused all the failure that made the ABS pump go but we are stretching things way out to left field here.
    Mikash Kumar likes this.
  3. ChapmanF
    15,709
    A bad hub can cause the ABS warning light to come on, but the warning light then won't be telling you about a pump or actuator problem. It will be telling you about the hub problem.
    The warning light has a hundred or so different reasons it can come on. That's why it's important to look at the trouble code to see what it's on to tell you about.
  4. Mikash Kumar
    Fiji
    Thank you for your expert response.
    I have replaced the entire ABS pump (which cost me $1500) now I have the old pump laying in my store room. is it of any use?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    Well, there is a possible grain of truth in that. You can have a problem with the wheel speed sensor or the "tone ring" (part of the rear wheel bearing- hub assembly) that causes the wheel speed signal to be erratic. The ABS can falsely activate during almost every stop, which can lead to parts wearing our sooner. But you would see the "slip" indicator on the dashboard.
    If you don't have warning lights on, then just deal with the hub because it's worn and noisy. (can't say that I have seen a bad REAR wheel bearing on a Toyota but it can happen).
    #5 mr_guy_mann, Nov 24, 2022
  6. ChapmanF
    15,709
    Rear right was the first to go on my Gen 1, followed by left front a few years later. Probably just depends.
