Does battery need charging after several days of not driving?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sara Lavendar, Aug 11, 2015.
  1. Sara Lavendar
    Sara Lavendar New Member
    Toronto
    I just bought a 2012 Prius c. There are oftentimes when I don't drive my car for a few days. When this happens, I have heard that the car might not start, especially in the winter. Is this true?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    A few day's?
    Shouldn't be a problem.
    "Life" kind of demands that a vehicle be able to sit unused for a minimum period of time. I've gotten colds and flu's and had my Prius sit for days...nearly a week, with no issue. People also park them for vacations and at airports. "Days"...even weeks on a newer Prius shouldn't be a problem.
  3. Mendel Leisk
    38,214
    if you regularly drive it at least twice weekly you should be fine. It should be more than just a drive 'round the block too. Less than that the battery may start to deteriorate.
  4. Sara Lavendar
    Toronto
    Thanks for your quick reply. What happens if I go away on holidays and the car doesn't get driven for a while?
  5. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Probably nothing inconvenient happens, if your holiday is under one month. Maybe nothing, if your holiday is under two months.
  6. bisco
    48,946
    keep in mind, we're talking about the 12 volt battery under the rear seat, not the hybrid drive battery.
    if the battery is in good condition, you should be able to leave it for up to 8 weeks no problem. but who knows what condition it's in?
  7. Sara Lavendar
    Toronto
    Thanks. This is good news.
  8. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    A couple of times I've left my C parked at A MI airport during winter for 3 weeks. When I returned the car started right up.
