Does Driver Side have most weight on tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusOnTheFence, Aug 21, 2020.
  1. PriusOnTheFence
    75
    29
    MA
    Which part of the car carries the most weight, given a single passenger, the driver?
    And should not the tire with the best tread be placed there, rather than mindlessly rotating?
    Presumably the second position with the greatest ware is the front passenger side.
    I am also not clear in the end of the Prius allows for cross rotation.
    Thoughts welcome, thanks!
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    The manual says cross not required. Send me your manual, I’ll pay for shipping.
  3. JC91006
    16,482
    8,399
    I always thought the front tires wear more because it's a front wheel drive and also there is additional wear when you are turning the car constantly. Does the weights on the tire have an relevance?
  4. PriusOnTheFence
    75
    29
    MA
    The greater the weight, the greater the wear. So I'd prefer to have my best tire under the driver, to even out the wear. But yes, front wheel drive means those two have the greatest wear.
  5. Mendel Leisk
    38,715
    Manual says to just swap front to rear, no cross rotation. Not sure why; a first for me. I've stuck with the manual instruction; it does mean two wheels have little curb rash.
  6. fuzzy1
    10,167
    For best directional control and stability during upsets and emergencies, tires should still be well matched side-to-side. So if there is enough left-to-right tread difference to matter at all, I'd be asking why. E.g. is there an alignment problem causing uneven wear?
    That is more commonly a tire issue, not a car issue. Check the tire maker's owner's pamphlet. All my non-directional tires over the past several decades have allowed cross rotation.
    As Mendel points out, the Prius Owner's Manual shows just a front-rear swap, no cross rotation. I suspect that as just a simplified recommendation so they don't have to tell owners to go look at the tire OM to determine whether or not cross rotation is allowed.
  7. PriusOnTheFence
    75
    29
    MA
    Yes, I noted that too and also don't understand why. The tires themselves don't have that restriction. Cross rotation allows you to even out the wear on the edges. And I'd seen some contrary views.
    But I stick to the manual too...
  8. bisco
    49,466
    front gets more pressure, i wonder why
  9. jerrymildred
    jerrymildred Senior Member
    11,510
    14,110
    Tampa, FL
    Front wears faster partly due to being the drive wheels, but also because there's normally quite a bit more weight on them, especially Gen 2 & 3. I think it's about 60% on the front.
    As for left and right, the engine and transaxle are not symmetrical in weight. I read somewhere that the right side is a bit heavier. Not enough to offset the weight of an adult behind the wheel, but it brings it closer to even.
    PriusOnTheFence likes this.
  10. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Second that. I rotated my tires last weekend, 3 tires were at 6mm tread depth in all 3 grooves but one tire was 7mm on all 3 grooves. That tire so happened to be on the left side of the car, for the record all 4 tires were purchased at the same time and I don't take hard corners nor majority of turns are right turns.
    jerrymildred and PriusOnTheFence like this.
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,172
    2,212
    Taylors, SC
    For many years it was front to rear and vice versa.
    Now, for front wheel drive cars, the cross rotation of the rear cross to the front and front directly is recommended by the tire manufacturers. Prius preferred tire rotation pattern.png
  12. PriusOnTheFence
    75
    29
    MA
    this is very interesting and sounds eminently reasonable. Can you give a link?
    Georgina Rudkus likes this.
  13. Georgina Rudkus
    3,172
    2,212
    Taylors, SC
  14. fuzzy1
    10,167
    That one appears to be snipped from a larger graphic from Discount Tire:
    "There are many different tire rotation patterns. Both tire and vehicle type will determine which pattern is best to follow. The different rotation patterns are illustrated below. ..."
    Here are some others ---
    Bridgestone:
    "The tire rotation pattern that’s best for your vehicle will depend on the type of tire you’re using, whether your vehicle is front, rear, all, or four-wheel drive, whether your tires are directional or non-directional, whether or not your tires are the same size on the front and rear of your vehicle, and whether you have a full-size spare that can be rotated through as well, unlike a temporary spare.. Let’s take a look at tire rotation patterns recommended by the standardizing body of the tire industry, The Tire and Rim Association, Inc., for all of these possibilities."
    Discussions of these, and more patterns for other situations, are on that page.
    MIchelin animated graphic:
    Tirerack.com
    I'm sure that you can find more tire market supply chain voices on this.
    #14 fuzzy1, Aug 21, 2020
  15. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Here's my 2 cent comment.
    Yes - front drive vehicles should wear the power tire more than the other three.
    Aligment - OEM camber and toe settings can wear the insides of the front tire at an uneven rate than the rest of the threads.
    The crown of the road - can wear the driver side tires more than the passenger side.
    Now - here what is done with many performance cars.
    Place a 100lbs sand bag in the drivers seat.
    Then corner weight the vehcile (typically with ride height adjustments, which I don't beleive Prius' has, so this may not be possible)
    Then get a custom alignment of toe and camber (another co-member may have a good spec for Prius', yet I understand aligning the rear suspension of a Prius is an issue)
    Lastly once set, moniter your tire wear to find an ideal pressure for even wear.
    A pryometer tool can be valuable in seeking alignment and tire pressure setting.
    Good luck.
  16. Mendel Leisk
    38,715
    As far as I can recollect, Honda's always said straight back and cross to front. Our son's got a Mazda CX-5 and I believe the same applies.
    Still, keeping them on same side with our Prius I found the wear quite uniform as well.
  17. jerrymildred
    11,510
    14,110
    Tampa, FL
    Since I couldn't find any specific tire rotation info on my Yokohama Avid Ascend GTs, I committed the cardinal sin of checking the owners manual. On page 594 of my Prime's manual I found this:
  18. Georgina Rudkus
    3,172
    2,212
    Taylors, SC
    The front back method assumes that the car is symmetrically loaded for the majority of the cars use. However, most all cars, and even most vehicles, are usually driven with the driver only. I prefer the "forward cross" method, however, because it rotates the tires to compensate for the 100 pounds plus constant additional moving load on the driver's side front tire. Theoretically, there would be additional wear on that tire due to the higher load.
  19. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Here are the corner weights as measured by Car&Driver, 2010 trim IV with no driver and a full tank of gas:
    jerrymildred and Mendel Leisk like this.
  20. PriusOnTheFence
    75
    29
    MA
    As I've said, I know the manual advises front to back rotation, but there seems to be no explanation why cross rotation is not allowed on a Prius, even when the tire itself lists no such restriction.
    Also, my point is that mindlessly rotating according to ANY pattern is not really the best solution. Ideally, you'd want to make sure that the tires with the best treads are on the front.
    I am saying this because in my last rotation I was left with my WORST tires on the front, and I made them change it.
