Does EPA test with Ethanol Gas for MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Nov 8, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I posted a similar thread sometime ago when the EPA conducts their test for MPG on new vehicles does the gasoline they use for that
    testing contain 10% Ethanol as quite a few states mandate for
    all year long use in their gasoline. I don't believe anyone really knows outside of the EPA and they are not telling.
    If they do use the 10% Ethanol blend you will see a 10% drop in MPG believe me.
    If the car compaines are conducting their own testing you can bet they will use regular gasoline with "NO" ethanol to get the best obtainable results.
    If your state does not use Ethanol in gasoline don't ever let them.
    alfon
  2. fuzzy1
    10,170
    The test methods and rules are published and available online.
    When I last looked, pre-2008, they had accumulated some adjustment rules to account for fuel blends of differing energy content, i.e. ethanol and other oxygenates. All results were adjusted back to reflect a traditional non-oxygenated fuel.
    Though memory is hazy, I don't think they even measure fuel volume at all, but instead measure the various forms of carbon coming out of the tailpipe.
    The change in MPG labels from the 2008 rule is greater than the small loss from using ethanol fuel.
  3. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    10% ethanol will not result in a 10% loss in fuel efficiency, unless the BTU output of ethanol is zero, it isn't
  4. Midpack
    Midpack Member
    461
    43
    Chicagoland
    FWIW
    Ethanol and Fuel Mileage | American Fuels
  5. Midpack
    Midpack Member
    461
    43
    Chicagoland
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Lets face it, in real world driving almost everyone in this forum always get more miles per gallon when they use non ethonal gas as opposed to ethanol gas. Sometimes in 5 mpg or better range.
    Here in Oregon just switching over to the winter blend was at least 3 mpg lower mpg's. (Oregon is mandated Ethanol in gas all year long)
    Also I believe that MPG's are more noticable in a Prius as compared to a Ford Crown Victoria, in dealing with percentages.
    alfon
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I don't think anyone here disputes the fact that ethanol contains less specific energy than gasoline. We do dispute the 10% reduction figure for 10% ethanol, as that is incorrect by inspection.
    It is easier to notice mileage variations with the Prius. The Prius mileage is so good that the absolute numbers are much larger than that for low mileage cars. The actual percentage change may be a bit larger, but it is in the same neighborhood.
    Tom
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The "studies" (particularly by those pushing ethanol) are questionable considering the loss in energy content. Rather than seeing a reduction in overall mpg loss, my calcs of driving my truck with/without E10 was a much higher loss than the energy content reduction.
    Here is a recent article from Down Under showing a 4.2% loss in a Camry. Porsche says their Euro testing is resulting in a 3% loss. False economy: E10 fuel isn't cheaper or greener - National - BrisbaneTimes
    This is inline withe the US govt's. own studies that indicate ~4% reduction in fuel economy with E10. http://www1.eere.energy.gov/vehiclesandfuels/pdfs/program/int_blends_rpt_1.pdf
    It is unfortunate that we are stuck buying this E10 against our will in many jurisdictions. Not only is it less economical, despite subsidies, but the fossil fuel use to make the ethanol likely makes this a heavily negative use of resources.
    Where you can, try driving with both on back-to-back tanks. Then draw your own conclusions.
  9. a64pilot
    771
    62
    Albany Ga.
    Three or four percent is believable, ten percent isn't.
  10. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    It's clearly not 10% for those that use only E10. My average certainly supports that. There could be a blending effect at play, unless those complaining are literally running their tank drive before filling up. Studies have shown results vary based on the level of ethanol, having less of an impact in some cases.
  11. Celtic Blue
    2,224
    139
    Midwest
    Ten percent is possible, although unlikely. I wouldn't consider it to be the norm any more than I would "1.4%" which immediately sets off the BS detectors. If the greater part of the actual power lost is *needed* to overcome overhead in the motive system, then it could very well be magnified.
    It could be analogous to skimming 3-4% of the revenue of a product...the impact on profitability of that product is more than a unitary multiple of skim. In the highway trips where I've compared mpg in the truck I would put the factor at something like 1.5 - 2X. Stop and go acceleration could have similar factors. Of course this will vary depending on vehicle and driving conditions.
    There is also some small effect from water dilution. Assuming the resultant mixture is not saturated with water the impact should be small and the extra vaporization energy not too great compared to the heating value. (Although it takes about 6-7 times as much energy to boil a pound of water as a pound of gasoline, the heating content of the fuel is much higher.)
