Does fuel economy affected by how much gas left in the tank.(full tank vs 3-4 bars)
Discussion in 'Prius c Fuel Economy' started by amilamad, May 9, 2015.
  1. amilamad
    amilamad Junior Member
    I read somewhere that the fuel pump is inside the fuel tank and its best to keep the pump drown in fuel for better fuel efficiency. Is this true ?.
    And does the fuel pressure affect the economy?.
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    The pump is reported to last longer when always covered by the fuel, but I have no reason to expect better fuel mileage.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Pump will keep the pressure constant. So pressure will stay the same until there’s so little fuel in the tank that pump is sucking in air. Sucking in air will also shorten the life of the pump.
    So fuel economy will be the same regardless of amount of fuel in the tank. Except for the small effect that the weight of the fuel will have.
    amilamad likes this.
  4. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The only impact on MPG is the weight of the gas in the tank. You would find it difficult to measure the affect of the small additional weight.
    JeffD
  5. bisco
    49,694
    this is an interesting hypothesis, i read it somewhere as well.:)
  6. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    Do I assume correctly this design is the same as all Prii at least Gen2+ ?
    We have had very few pumps replaced to my recollection.
    No mention of better MPG with fuller tanks from the experts (800 miles per tank crowd).
    Maybe this is one reason Toyota makes us fill the tank with still 2-3 gallons when the pip starts blinking
