Does Gen 3 high voltage fan needs cleaning?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Apr 12, 2020.
  1. kehyler
    kehyler Member
    68
    26
    blah
    Hi All,
    For those that have personally cleaned the high voltage fan on their Gen 3 Prius, would you say that it was dirty enough to warrant the cleaning?
    I'm considering doing it, if it is worth the hassle.
    Thanks,
    -kehyler
    49,393
    you can't really go by others experience. it's all over the place. worth taking a look yourself.
    it might just be a little buildup, but if you live in an area with dirty air, it might be worse
  3. Mendel Leisk
    38,652
    Watch the @NutzAboutBolts video, pinned in the 3rd gen maintenance forum. I managed it first time without watching the video, it's pretty much follow-your-nose, takes an hour or two. A couple of tips:
    1. The hatch floor is secured to the top of the battery case with REALLY tenacious fasteners. Just take your time, have some decent pry tools, they will pop up. I left most of them off when reassembling, made the next time much easier.
    2. Aforementioned video shows rear seat bottom being pulled off. That's a lot of hassle, could break fasteners, and really not necessary. Where the battery inlet grill is, push apart the seat bottom and back, get some light in there, and reach a long ratchet extension with a 12 mm socket to the one bolt that needs removal. Get fingers on it for when it comes loose, so you don't drop it.
    #3 Mendel Leisk, Apr 12, 2020
  4. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I think the question is whether folks found debris in their fans after all the work. I looked at the fans in my Prius over the weekend. It’s a Plug-in, so it’s very easy to check them. It was the first time I’d checked them in three years. In that time, my girlfriend’s had her dog in the car dozens of times. That dog sheds like mad. Hair everywhere.
    Except on the cooling fans. They were perfectly clean after three years.
    Raytheeagle likes this.
  5. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Things to consider:
    Are you the original owner? If not, who/what rode in the care before you got it (pets, hirsute, slovenly passengers, yetis, etc)?
    Have YOUR pets (if any) been in the car?
    The car is, after all ten years old.
    Bottom Line: You won't know until you actually LOOK. Peace of mind, it's a good thing...
    Mendel Leisk and Raytheeagle like this.
  6. ASRDogman
    ASRDogman Senior Member
    6,062
    3,255
    Did you check the rest of the system? The fan may be clear of fur, but it could be clogging up between
    the battery cells. Think of where/how the air flows. That's where fur is!
    So the fan may be clear, that doesn't mean it's not starting to build up in the rest of the system.
    Though I would say it's a good sign the fan is clean. Do you have a filter on the intake?
    Is the plugin version the same as the standard Pruis? The intake on the right hand side of the rear passenger seat?
  7. Rebound
    3,964
    2,613
    Portland, OR
    The Plug-in is different. Same intake, but the hose goes to the rear of the car. Cleaning the fans is very simple on the Plug-in.
    NutzAboutBolts doesn’t have a Plug-in, so the expert professional video is here:
    ASRDogman likes this.
  8. ASRDogman
    6,062
    3,255
    Wow, that was just too easy! The Prius is like a big Lego!
    So where does it get the intake air? My cargo area gets hotter when I have the
    retractable cover extended. Is there a passage way to receive the cooler(in summer) air
    from the cab area?
    You do lose a lot of storage space because of where the battery is.
    Thanks for the info and for the video!
  9. Rebound
    3,964
    2,613
    Portland, OR
    It’s ridiculously easy!
    The intake air comes from the same spot as the standard Prius — a vent near passenger side rear seat. And it exhausts the air straight down.
    I love the Plug-in. My big surprise is that the bigger battery makes for much better mileage. I’ve gone very long periods without plugging it in, but still get 50 mpg regularly. I think the bigger battery captures and releases far more power than the standard Prius battery.
  10. Mendel Leisk
    38,652
    Yeah I've heard that. It's a little heavier, but there's a net benefit to the larger battery.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    The Prime is no different :).
    Trade in the garage queen and very little fuel purchasing going forward as your driving is so minimal:whistle:.
    You should be able to get a fair bit on trade in, and the PIP rims would convey to the Prime;).
    Win-win-win(y).
  12. Mendel Leisk
    38,652
    It'll probably be regular hybrid, if and when that day comes.
    Grit and Raytheeagle like this.
  13. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    I forgot about your spare tire requirements :cool:.
    But there are solutions to that:):
    Ready just in case(y).
    Grit likes this.
  14. Mendel Leisk
    38,652
    Plug-In is overkill for our needs. We're doing about 8K kms a year, lol. This year might end up under 5K, with COVID.
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    How many of your trips are under 25 miles or 40 kms:whistle:?
    My bet is most of them;).
    So you'd buy gas a whole lot less :).
    Just one benefit(y).
  16. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    2012 Prius v. Did it myself at about 56k miles in 2019. From the complete lack of scratches on the blower, I know it was the first time ever. I did it soon after getting the car, after reading on here about it.
    In my case, it was a waste of time. Very thin dust layer on the fan, which I did clean off after going through the effort to get in there. I will clean it again at 400k miles, or if I'm in there anyway to work on the traction battery. It does sound like different people have different experiences. Maybe if a pet always rides in the car ...
    But I'll suggest it may be useful to at least familarize yourself with the intake for the fan so you can be sure it stays clear. That location is different on different years/models.
  17. ASRDogman
    6,062
    3,255
    It's not a waste of time. It's peace of mind. Now you KNOW it's clean.
    And you know how long you can go before you start thinking about cleaning it again. :)
  18. ASRDogman
    6,062
    3,255
    Why does it keep posting me twice??
  19. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    Thought there would be a check engine light with a message saying to clean the fan if fan needed cleaning.
