Does Gen 4 Prius need an oil catch can?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Misplaced10mm, May 9, 2021.
  1. Misplaced10mm
    Misplaced10mm Junior Member
    2018 Prius
    I own a 2018 Prius V (Canada-only release) which is basically identical to the 2017 Prius V. I've been hearing all sorts of talk from 3rd gen owners about the importance of an oil catch can. Does the 4th gen need this? Any other "must-knows" about 4th gen Prius or is it an overall improvement over previous gen?
  2. Tideland Prius
    16,125
    Are you thinking of upgrading? Your Prius v uses the same engine tuning as the Gen 3 Prius, not a Gen 4.
    alanclarkeau likes this.
  3. Mendel Leisk
    38,646
    Mambo Dave, amos, m.wynn and 2 others like this.
  4. Samuel Williams Jr
    246
    Dayton NV
    Well where is your EGR valve located? It's either under the hood Gen 3 or by the cat and water cooled Gen 4.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    I put an oil catch can on our 2019 Prime (Gen4 underpinnings):):
    What did you do to your Prime today?
    I've caught about 5 ounces in the 20k miles it has been installed:cool:.
    And that's at 33% HV:whistle:.
    So a catch can on a gen4 does catch material;).
    The catch can works(y).
    amos and m.wynn like this.
