Does genII have a fuel pump?
Discussion in 'Gen 2 Prius Main Forum' started by Rph74, Jan 17, 2014.
  1. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    I just got stranded by one of my other cars from a bad fuel pump. For fun, I decided to see what the cost of a Prius fuel pump would be. I could not find a part for sale even from Toyota. So is there a fuel pump on this thing or some other method of fuel delivery?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is in the gas tank, which you replace as a unit. (One of the many reasons not to run your car out of gas is that it can over heat the fuel pump, normally cooled by gas)
    dbcassidy and Silver bullit like this.
  3. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Ah that makes sense now. Thank you! I noticed the fuel tank is 'only' $398 from Toyota so that actually doesn't seem to bad really. I am spending $800 or so on my Range Rover fuel pump and $100 on the fuel filter so the price on that entire tank seems cheap!
  4. El Dobro
    El Dobro A Member
    7,095
    3,272
    I guess it comes as a unit because of the bladder.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  6. bisco
    52,521
    agreed, that seems very reasonable, as toyota parts go.:rolleyes:
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    How many Prius have a gas tank failure that leaves a car to attach a new gas tank to?
  8. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    How frequent has fuel pump failure been reported on our genII's?
  9. Mike500
    Mike500 Senior Member
    2,593
    767
    Fuel pump failure usually occurs when the car has 150,000 to 200,000 plus miles on it.
    That's when the brushes wear down to nothing and short it out.
  10. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    All the above only relate to the North American gen2 Prius. In all other markets where the bladder is not used the fuel pump can be changed along with the fuel level gauge unit and the fuel filter. The unit can be removed and the filter cleaned if required.
    John (Britprius)
  11. El Dobro
    El Dobro A Member
    7,095
    3,272
    Well, it would be nice if members put, at the least, a general location in their profile. ;)
  12. Mike500
    2,593
    767
    The bladder system found in the Gen II was one of those "high tech"cutting edge" ideas, that looked good on the drawing board and execution, but has "unintended consequences" in long term use and serviceability.
    Don't "overfill" the bladder system at the pump.
  13. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    Thanks for that advice. I had been trying to pump in a bit more after the pump clicks. I won't do that anymore.
  14. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
    TELL ME WHY NOT "overfill" the bladder system at the pump, I do it all the time
  15. Mike500
    2,593
    767
    You surely haven't read the precautions and experience related by others on PriusChat.
  16. ski.dive
    967
    245
    I have been overfilling at the pump on my Prius since 2008, no issues....
  17. Mike500
    2,593
    767
    Your car! Keep on surfing...
  18. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    Another datapoint. A coworker had fuel pump failure on a 2006 last year @ 7 yeabout 110,000 miles.
  19. silverone
    silverone Member
    84
    34
    Ohio
    2014 Chevy Volt
    ...7 years and about... Don't know what happened there!
