Does grill block reduce engine oxygen intake?
Discussion in 'Gen 2 Prius Technical Discussion' started by 2009Prius, Sep 15, 2009.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    It's getting cooler so I just blocked the upper grill for the first time. :) I noticed the fuel economy of the first 5 minutes seems have dropped from before the grill block. (Correction: This may be just noise.) :( My question is that whether the grill block would reduce the oxygen going into the engine, especially at low speeds. :confused:
  2. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Odd how blocking the grille reduced your fuel economy. With my 2004 Prius, it generally helped, especially in temps <0 F
    Like most modern cars, the Prius doesn't draw any intake air from the grille area, but from the fender
    It could be a coincidence, but remove the grille block and see if that returns fuel economy to normal. There could also be a mouse nest in the intake piping somewhere, and be sure to check the air filter housing by removing the air filter
    2 people like this.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    How many times on your regular route have you looked at this? It really doesn't make sense. I think for most of us, except in the coldest weather, the grill block has little or no impact during the first 5 minutes. It does seem to improve engine warm-up time, but most importantly it keeps it from cooling down and allows it to stay warm and efficient.
    2 people like this.
  4. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    doc is correct. It should not reduce oxygen supply to the motor, but it should assist with engine warm up time. It keeps the cold air from blowing directly in on the engine compartment. I seriously doubt that is what is affecting your first 5 min. bar. Did you block upper and lower grill? I have blocked mine ever since I purchased the Prius, and have never had any trouble whatsoever.
    2 people like this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    IMO the blocked grill isn't the cause. You said it's colder now. That's the cause. In moderate temps I don't see much of a difference & expect 25mpg for the 1st 5 minutes & 50mpg for the next 5. Even with the grill blocked some winter mornings I wouldn't be surprised to see minus mpg. After the 1st 10 minutes you should see some improvement & green bars more often. Over the winter you may find that the lifetime average was maintained instead of decreased but this is very dependant on the OAT.
    2 people like this.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Wow, where is it colder now? Here in the "great white north" we're having a hot "Indian Summer". It's supposed to get up to 30C today (about 80F), about as hot as it gets even in summer!
    Grill block is the furthest thing from -my- mind. ;)
    But yes, as the above posters have said, the upper grill block will not decrease the engine's air supply, nor will the lower grill block. The engine breaths from just in front of the passenger front wheel. And I've also never seen a decrease in fuel economy from grill blocking. It -should- improve it slightly as it would lower drag a bit. But probably not enough to see.
    2 people like this.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    I tried an upper grill block for the first time and had no improvement in fuel consumption over earlier in the winter. I removed the grill block and my consumption improved by 0.1L/100km. I don't know why.
    2 people like this.
  8. 2009Prius
    2,705
    510
    63
    Thanks to everyone for sharing your knowledge and experience. The "reduced first 5 minute MPG" may be just noise. Sorry about that. I will edit the original post.
  9. jayman
    13,439
    639
    Winnipeg Manitoba
    Unusually hot here too. This time of the year, I'd have the A/C turned off and covered up. We're getting our July weather a bit late, but at least we're getting it
    That's odd. I would usually start grille blocking once the temps were around -10 C consistently. I do know that at -30 C and colder, the grille block makes a big difference in comfort
  10. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I have all top grills blocked and 3/5 from top to bottom of the bottom grill blocked. It is about 40F in the morning and gets up to about 70F highest in afternoon. I drive about 45-60 mins on rolling hills at around 40mph. I don't have any temperature monitor, is this going to get my car too hot or can I go ahead and block another bottom grill?
  11. jayman
    13,439
    639
    Winnipeg Manitoba
    Without any way to monitor temps, I'd hold off blocking more of the grille until the temps got colder. I never even started blocking the top grille until the temps were consistently -10C
  12. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I improve greatly when I only do about a 50 % block and even run it in the summer. I block the lower half of the top (chrome section) and then 3 slits on the bottom year round. Most of my trips are about 20 miles. I pull all the lower block off if I plan on driving long distances at highway speed or if its unusually hot (+ 90 degrees) meaning I will have more A/C use. My rule of thumb is that if the radiator fans click on its time to pull some off.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    getting close to the time of year where i would start blocking as well, but forecasts are for the mid 80's next week so putting that idea on hold for now.
  14. patsparks
    10,664
    567
    Could it be that cold here is 4 C minimum and max of 13 C?
    Day time temps here lately have been 12 C to 21 C.
    We had a couple of days over 25 C so I removed the grill block, I doubt I'll be putting it back in.
  15. jayman
    13,439
    639
    Winnipeg Manitoba
    Sorry Pat, we don't call +4 C "cold" in this country. In Spring, we call it "summer"
  16. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    We had 3C the other morning, and it's still summer for another day or 2 :)
  17. jayman
    13,439
    639
    Winnipeg Manitoba
    We're getting our July weather right now, have had highs in the 30's, lows of 10 C and warmer.
    Back in July, I still was using heat. I felt like sparking up my gas fireplace early
  18. patsparks
    10,664
    567
    On the 15th of August it was 28 C here. That is over 2 weeks inside winter here.
  19. 2009Prius
    2,705
    510
    63
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the fan does come on supposedly at at relatively low temp. but i had not heard it run for YEARS. but only because i jus had not been around it.
    this past summer, i heard it run, but was hardly an event. the scenario, OAT was 101 º F.
    had driven about 30 miles one way on freeway, jumped off freeway because passengers with me had bladder issues. so, i actually hit the power button instead of the park button and figured, i turn it on when they came out. well we stopped at rest stop so it was an immediate off freeway and park thing.
    well, about 2 minutes after the car was turned off, the fan came on and it was relatively loud and very noticeable. well, it ran about 15-20 seconds and shutoff. was off like a minute. came back on, ran another 15 seconds and shut off that was it.
    in retrospect, i can see why i never heard the fan much...it simply does not run that much. didnt have scangauge on the Pri at the time, but guessing water temp was probably in low 190's when running and spiked a bit when i shut down. during winter, my water temp is nearly always high 190's to low 200's and i never have heard fan run in winter. so apparently, the engine cools off pretty fast and i have verified that parking for as little as 10 minutes in relatively mild winter weather is enough to restart the warmup process
    2 people like this.
