Does heat do more damage to a fully charged HV battery or depleted battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Jun 15, 2015.
  1. JC91006
    16,496
    8,406
    Since summer is now here and the 100 degree heats are the norm, would you HV battery experts think the heat would do more harm on a fully charged battery or one that's been depleted?
    There are cars that I don't drive all the time and they are left baking in the sun. Should I store them full or depleted in the heat?
    49,735
    fully charged. as you know, i am not an expert. and i maybe thinking about li-on.
  3. JC91006
    16,496
    8,406
    I thought batteries expand with heat.....so I was thinking more on the depleted side. But I really don't know either
    49,735
    do you use window shades or anything?
  5. JC91006
    16,496
    8,406
    yeah, the windshield shade, but that doesn't do anything when the temperature gets over 100 degrees
  6. bisco
    49,735
    that is hot. is it a dry heat? not that it matters to a battery.
  7. CR94
    CR94 Senior Member
    2,642
    1,139
    Northwestern S.C.
    somewhere roughly midway between is better than either extreme, I think. (I don't know exactly what degree of charge would be optimum, though). Note that the battery management programming in the car won't let you fully charge or fully discharge the battery, despite what the display may show.
  8. bisco
    49,735
    good point. i think we do know that arizona and texas batteries have a higher failure rate, don't we?
  9. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    I think this might be a "how many angels can dance on the head of pin" kind of question. But I like it!
  10. alekska
    alekska Active Member
    435
    138
    Atl
    Fully charged battery is more damaged by high heat than empty one. This was discussed many times here.
    - Alex
    JC91006 likes this.
  11. JC91006
    16,496
    8,406
    I'm glad somebody follows those threads......
