Does it make sense to shift to neutral during driving?
Discussion in 'Gen 2 Prius Fuel Economy' started by dominicsavio, Dec 23, 2008.
  1. dominicsavio
    dominicsavio New Member
    83
    Folks,
    I'm wondering on a technicality (to increase fuel efficiency) and need some input:
    When driving downhill (or even coasting a modest speeds for that matter), does it make sense to shift to Neutral to take FULL advantage of gravity (or momentum)?
    When the car is in Drive, it is still partially engaged and will not run completely free under the effect of gravity (or momentum). However, when you shift to Neutral (while going downhill or even coasting towards a stop), you can go further quicker because of the 'free flow'.
    I've tried this with conventional manual shifts and it works just fine.
    I'm guessing that for the Prius this needs to be weighed against losing regenrative braking or battery recharching (becase shifting to Neutral disengages the motor/battery)?
    Thanks!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    1) It's probably illegal to do so.
    2) It's potentially unsafe to do so under some conditions (see #1)
    3) Yes, it makes sense if you're in a glide below 41mph. It's the lowest energy use/waste state you can be in ASSUMING the ICE is not spinning when you go into neutral.
    4) Going into neutral when you are already going over 41mph does not make sense b/c it will force gas burn to keep the ICE spinning.
    5) Most of us recommend learning how to glide and hyperstealth glide instead of using neutral.
    6) If you do go into an ICE-off neutral below 41mph then coast down hill to a speed above about 62mph you may exceed the 10,000 rpm rating of MG1 and could damage it resulting in costly repairs.
  3. dominicsavio
    83
    Thanks efusco. In terms of gliding:
    1) Whats the most efficient way to start from a stop/slow roll? I've seen your document recommend depressing the gas pedal 1/3 way to "rev" up speed but is this most efficient (vs. slowing to a speed by initially using solely the battery?)
    2) When driving at a constant speed of 40-50 mph (which is probably the zone of most efficiency), is it better to do so under cruise control? I've done this a couple of times and my mpg monitor does not cross the 40 or 50 mark
    3) what is hyperstealth gliding? Is it working the gas pedal so your ICE is off and your battery is driving the car?
    Thanks!
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Remember that N in the Prius does not disconnect anything, unlike a normal car. All of the pieces and parts are always engaged, and there isn't any way around it. What N does do is keep the control system from doing regeneration, powering the vehicle, or changing the state of the ICE. It could help, but it's better to feather the accelerator pedal.
    Tom
  5. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    no.
    it's pointless in the prius. Besides you don't get regen gains in N
    just keep it in D
    on regular cars with an auto it can help FE, but it's illegal in most states
    if you want to shift gears, get a car with a stick
  6. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    1) Evan might have a different answer, but I "goose" the go-pedal just enough to get the ICE to light, then back off enough to allow modest acceleration. I want to minimize battery use as much as possible. By "modest" acceleration, I suggest keeping the instantaneous MPG at least half the vehicle speed. This keeps the ICE within efficient operating ranges.
    2) Actually, at steady speeds the car operates more efficiently at speeds below 41 MPH (most efficiently at 20, in fact) where the ICE will shut down completely when not needed for propulsion. But assuming driving conditions mandate 41+, I avoid CC except on level terrain. Because of its goal of holding a precise speed, it pushes the ICE into inefficiently high ranges on uphills. See this for more.
    3) Hyperstealth is another name for "warp stealth," which is reviewed here in great detail.
    I disagree. First, in states where it is illegal, it generally is illegal only on downgrades. No state outlaws it on level terrain or upgrades that I know of.
    Second, as Evan suggests, it is an alternative technique for gliding and, IMHO, a good one. (For the OP and others unfamiliar with gliding, do a good search on "pulse and glide.") True, there is no regeneration, but gliding is not done to regenerate. In fact, it deliberately avoids regeneration and enables better fuel economy by maximizing use of available kinetic energy. Using neutral is easier, draws less off the battery, and provides at least the same fuel economy as (and possibly better than) feathering the pedal. See this (rather long and somewhat technical) link for more.
    To Dominicsavio, I wouldn't normally bombard a newbie with links so detailed, but you seem more interested in driving technique than many. Take your time, study these and the many good threads on P&G, practice, and have patience. I still am fine-tuning my technique after three years with the car. The results pay off: MPG in the low to mid-60s as of now, and often 80+ (with occasional trips above 90) in warmer weather.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    This is a tricky question as no one answer is applicable in all cases.
    Evan gives a good summary of the many little considerations:
    and other folks have added more tangential considerations.
    [Edit: And JimboK's post has some real meat in it to be slowly digested.]
    In my experience, in general the answer is no, the energy savings are very
    small.
    That said, in some very specific case it might be worth considering. And that
    case is probably imbedded in a larger situation that you've been able to
    analyze over many repetitions.
    Let's look more closely at Evan's point #3 above:
    "3) Yes, it makes sense if you're in a glide below 41mph. It's the lowest
    when you go into neutral."
    Gliding in neutral uses about 1/3 the energy from the HV battery that a "no
    arrows glide" does. So if you're in a situation where maintaining high SOC is
    really important, and the distance to be covered is longish, an ICE-OFF N
    glide could be helpful.
    I've got just this kind of situation in my daily, 28.8 mi round trip commute.
    I have learned that how I handle a 1/2 mi. section at the end of the in-bound
    morning run will make a 5 MPG difference at the end of the day. And getting
    that 5 MPG involves a long ICE-OFF N glide at 25-30 MPH to keep the SOC as
    high as possible. (I have a ScanGauge, EV switch, and grill blocking.)
    You see, if when I leave the parking garage heading home I have a high 6
    bar, or better yet 7 bar SOC, I can EV through a 1/4 mile run of stop signs,
    traffic lights, and low speed right angle turns and have the SOC at 4 bars.
    [Edit: And air temps are above 32 deg F, as EV mode is unavailable to me
    at lower temps. Yes, there are many things that can nix this whole approach.]
    I know that once the ICE kicks on anywhere in the run, it will continue to run
    when stopped at least until the colant temps are above 130 deg F.
    I will admit that in the morning it is a very delicate dance indeed, sometimes
    letting the ICE run when I could "no arrows glide." But as best as I can
    arrange it, that ICE-ON time keeps the temps up, saves or slightly add to
    SOC, keeps me moving with traffic, and reduces MPGs by only ~0.2.
    But this intentional ICE use plus the SOC saving ICE-OFF N glide sets me up
    for the 5.0 MPG gain later on.
    In my daily driving, this is the only time where I've found an ICE-OFF glide is
    helpful.
    You'll have to look carefully at your daily driving conditions to discover if
    there is some different situation that might work for you.
    Hope this helps.
  8. qbee42
    18,058
    3,073
    Northern Michigan
    These are good answers, and no one answer to this question will work for every driver. The different answers basically come down to three different viewpoints:
    1) Legal - As pointed out, there are some legal issues related to N, almost all of which are carryovers from the days of manual transmissions, where a driver could lose control of a vehicle not in gear.
    2) Efficiency - Pulse and glide is an efficient way to move a Prius for hypermiling. With N you can P&G with less fuss.
    3) Need - There isn't any need to pulse and glide, or shift to N, or use any other hypermiling technique for ordinary driving. If you are just driving your Prius for simple transportation, then you don't need to worry about fancy techniques. Just drive it and it will do pretty well on mileage.
    Tom
  9. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Why would you shift into neutral and risk all kinds of problems when if you back off the pedal to the sweet spot you'll find the power mode go into its own 'neutral' evidenced on the MFD as no power from the ICE nor the battery (everything grey).
  10. JimboK
    2,817
    187
    49
    Chesterfield, VA
    I present my "why" in the link in my previous post. As it shows, there actually is more battery power consumed during a pedal-feathered glide.
    What are these "all kinds of problems?" There are only two easily-managed risks that have been raised: the illegality of it on downgrades and the (theoretical) risk of over-revving MG1 that Evan mentions. The latter would occur in conditions that most drivers will never see, even if they routinely use neutral. It has to be invoked deliberately and then (and only then) it will happen in very limited circumstances.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I have done this for years with my other cars. But, with the Prius it does not help. I tried this extensively on two half tanks and I actually got worse mileage! As the other posters have said apparently the ICE keeps spinning. However any mode that you are in which does not use the engine is a good mode, whether your running from the regen feedback, the battery or in glide (stealth) The magic normal speeds are 30-40MPH. Generally difficult to maintain under normal driving conditions.:cheer2:
  12. dominicsavio
    83
    These are all good points. I've tried coasting in Neutral with my previous car (conventional 4 cylinder gasoline engine) and was able to push the fuel efficiency up to 33-40 mpg (depending on cit/hwy/hot-cold temp). The important thing to remember here is that in Neutral, the engine is disengaged from the powertrain (i.e. the car is in a "free-run") so regardless of the speed (i.e. wheels turning), the rpm still stays at a minimum (this was an old car, not sure if this still happens in newer cars).
    This experience left me feeling that "Neutral" is the best way to take advantage of momentum/kinetic energy to directly drive up fuel efficiency.
    The Q is, in a Prius, does Neutral mean the same as above? I guess not because you still probably run the risk of revving up the engine at high rpm (I wish Prius had an rpm indicator).
    Would someone please explain why going downhill on Neutral (in any car) is illegal (or unsafe)? I understand this means that the car is not in 'gear control' but so what - you are still driving with brakes (as you would if the car was in gear)?
  13. qbee42
    18,058
    3,073
    Northern Michigan
    No, in a Prius everything in the drivetrain is connected all of the time. There is no clutch or shiftable gears. Look up HSD if you want the details.
    Coasting in N is illegal and considered dangerous because it was and is potentially hard to get back in gear with a manual transmission. In the days before synchromesh gears and good brakes, you could find yourself coasting faster than intended, with no way to slow down. Most of this doesn't apply anymore, and none of it applies to the Prius.
    Tom
  14. JimboK
    2,817
    187
    49
    Chesterfield, VA
    A key point to using neutral effectively in a glide and, therefore, as a fuel-saving technique, is for the ICE to be off when the shift to neutral is made. As Tom has suggested, the ICE remains in whatever operating mode it is in when the shift is made. So if the shift is made with the ICE on, it remains on in neutral and, of course, is running inefficiently. Andyprius, maybe that explains why your fuel economy worsened.
    Then it is important to know that the ICE won't spontaneously shut off until the car has progressed through its warmup stages. But once the warmup process is complete and the shift is made at <40 MPH, the ICE will not be spinning.
    There is no risk in over-revving the ICE. If it's on during the shift, it simply runs at idle speed afterwards. The theoretical danger is in over-revving MG1. But that will happen only if the shift is made in an ICE-off condition at <40 MPH before a long or steep downhill that then allows coasting up to ~62 MPH. If the shift is made at 40+, then the ICE is running at the shift (before full warmup) or, as protection for MG1, spinning without fuel flow (after warmup).
    Dominic, there are many that share your wish for a tachometer. Some have a ScanGauge to monitor RPM and various other operating parameters.
  15. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I never have liked putting automatic transmission cars in Neutral when driving, much less do I like it in the Prius with the CVT. In either case, it seems that when the car is at speed and shifted from Neutral back into Drive again the RPM's rev up like the computer is trying to find out what ratio or gear it's supposed to be in and adjusts it from there. With the engine revving up in the Prius when shifting back to Drive again I would think that it would probably defeat most if not all of any benefit you may have gained by going into Neutral. I personally think you'd be better off (and safer) by just feathering the accelerator to where the MFD shows no power being consumed or regenerated.
    I don't completely understand how the Neutral in the Prius works mechanically, but in the case of a regular automatic transmission I would think it causes excessive and unnecessary wear & tear on the tranny. This may or may not be the case with the Prius, but still I've only done it at moderately low speeds just to see how it would react and I didn't like it and will not do it at any higher speeds (~40+). I'm also curious, anyone ever tried Reverse or Park at any speed to see how the car behaves? I'm pretty sure I've tried Reverse before and it just beeps at you, and I don't dare to try park. Just wondering how smart it really is.
  16. qbee42
    18,058
    3,073
    Northern Michigan
    How does N work in the Prius mechanically? It doesn't. Neutral in the Prius, as well as all other gears, are mechanically the same. Nothing changes. All of the same gears remain engaged. The only thing that changes is how the control system runs MG1 and MG2.
    Tom
  17. dominicsavio
    83
    A few clarifying questions:
    1) What is MG1 and MG2?
    2) Why do people quote "41 mph" as a cut-off speed for ICE activation?
    3) When I turn "ON" the car in the morning in my garage (after it has been parked overnight in freezing temperatures), after a few seconds, you can "hear" the car "whirl up" (while it is still parked). I'm guessing this is the ICE firing up? If so, does this happen just to bring the powertrain to an efficient operating temp? Also, I'm assuming gasoline is used during this process (although your MFD would not indicate any arrows because the car is not propelling)? I'm wondering if it is a good idea to let the car warm up for ~10 min before engaging "Drive" (again all this with the aim of maximizing fuel efficiency)
    Also, to responde to Tom's post:
    "Coasting in N is illegal and considered dangerous because it was and is potentially hard to get back in gear with a manual transmission. In the days before synchromesh gears and good brakes, you could find yourself coasting faster than intended, with no way to slow down. Most of this doesn't apply anymore, and none of it applies to the Prius"
    Why would it be hard to shift into (top) gear when coasting downshill in neutral in manual transmission? All this would require is to press the clutch to lock in the gear and rev up the engine. And you could ofcourse slow down using your brakes (just as you would were you propelling downhill under gear). I'm still trying to understand the safety issue here...(I do not have experience with automatic transmission so if this applies only to automatic, I may be missing the point)
  18. JimboK
    2,817
    187
    49
    Chesterfield, VA
    1) Sorry, we sometimes forget that newbies don't know the vocabulary. :blush: MG1 and MG2 are the two motor/generator units. See this thread, including the many good links within it, to learn more about the HSD (Hybrid Synergy Drive) system and power flow.
    2) 41 MPH is the quoted threshold, simply, because that's the way the car is designed, for reasons known to few other than Toyota engineers.
    3) What you're hearing on startup is indeed the ICE's initial firing, in the first of its warmup stages. It takes several minutes to reach its most efficient operating temperature (157F+), so it's not operating at its most efficient until then. See the link I provided previously in post #14 for a full description of the warmup process.
    Do NOT let the car sit and run during warmup if you're interested in efficiency. It's burning fuel needlessly. Better to get in and start driving.
  19. efusco
    19,891
    1,191
    Nixa, MO
    41mph is magical b/c above 41mph the ICE MUST spin (unless you go into an ICE off neutral and coast to a higher speed). Below 41mph the ICE can spin when necessary, but you can also get into stealth mode (ICE off).
    Thus, for Neutral to be effective you can must be in an ICE off condition--only achievable under 41mph. But you're correct in that just being under 41mph does not necessarily mean that the ICE is off.
  20. dominicsavio
    83
    Thanks! This means that when you are cruising at optimal speed (42-50 mph; =speed for maximum fuel efficiency), you are always propelling with ICE "ON". Why would these conditions translate to maximum fuel efficiency? Wouldnt you argue that the optimal speed would be 35-40 when you have periods of ICE "off" (= more fuel efficiency)?
    I'm assuming that in the 40-50 range, propulsion is solely by ICE and additional contributions of the battery are nil or insignificant
