Does leaving the fob in car do anything.
Discussion in 'Prime Main Forum (2017-2022)' started by 8Nguy500, Dec 31, 2023.
  1. 8Nguy500
    8Nguy500 Junior Member
    24
    Wisconsin
    2019 Prius
    I had this experience from Thursday afternoon till Saturday morning. I left my fob in the cup holder on Thursday. I was getting a low battery waring message. Car was parked in front of the house. Not I do not want to hear how this is how you car can be taken anf here is why. I live in a rural area a half mile off the main road. No foot traffic, many be a few deer.
    On Saturday morning I went to take garbage to the dump, windows were ice covered. When I went to start the card I got a message to hold fob next to the start button and push. Car started, I set the defroster for windshield and began to scrap the ice. Half way around the car the car shut off, maybe 5 minutes or so.
    Finish the window work, went to start the car again fob next to starter button nothing, message low 12V battery. Hook up the chatger on a 10 amp setting for about 10 minutes. Car starter right up. When to the dump and post office and drop home. Total time 17 minutes. When home.
    Upon parking the car I notice the check engine light on. Decided to go to The Irish auto parts store to have then read the error and reset the light. Cleck said he has never seen this be fore but the reading was a failed and he would not reset the check engine light (lawyers?).
    So I drove, struggled to use my own reader (one I'm on the ground tough to get up) reset the light.
    Any thought on what happened?
    Thanks for you time and thoughts.
    Jerry Z.
    49,488
    having the fob within range of the car puts more drain on the fob battery and 12v as the fob and car communicate.
    other than that, i can't think of another issue.
    you will need a more prius aware scanner for the correct code and sub code
  3. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Fob Battery goes bad quicker...
  4. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    It's the way these new smart keys work.
    The fob needs to be in radio communication with the car to serve as a control device.
    Normally the car polls for the key every few seconds. This poll-and-sleep recheck behavior is done to save battery power.
    Once the car detects the key nearby, it changes to continuous polling so that it can respond instantly if needed. Because the radio usage is constant, this mode uses more power.
    This works fine for owners who remove the fobs from the car when they are done driving.
    You may need to plan on additional 12v charging.
  5. Mendel Leisk
    38,726
    I’d start taking the fob with you, prep for possible replacement of current battery, and depending on what you currently have, maybe invest in a newer, smart charger, in 4~5 amp range.
  6. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    The cold didn't do your batteries any favors either. Put the 10A charger on it for a couple of hours. Then go back to the Irish auto parts store; have them run a battery check/load test. If it's good, keep an automatic trickle charger on her, otherwise replace the battery.
    Hope this helps...
    PS. also check the electrolyte levels before charging - I'm pretty sure you have access the battery using a quarter to unscrew the plugs.
    #6 BiomedO1, Jan 1, 2024
  7. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    I assume you got the "low FOB battery" warning, not the "low 12V battery" warning.
    By the way, you are posting in the Prius Prime (PHEV) forum, but your signature says you have a 2019 Prius Limited, the normal Hybrid, not the Plug-In.
    This would be due to the car not recognizing the fob due to low fob battery.
    When you say car started and then shutoff, are you saying the gas engine was running and then it shut off? Did you check to see if the Defroster was running?
    So now you've drained the 12V battery because for some reason it wasn't being charged while you were warming it up. For some reason, your car must not have been in READY mode.
    The Prius will charge the 12V battery when you are in READY mode and not in Neutral. It doesn't matter if the gas engine is running or not. It uses the Traction Battery to charge the 12V.
    Doubtful the Check Engine Light is related to your battery issues. However, a code reader needs good power and the car to be in READY mode in order to scan the codes. Maybe the Irish auto guy didn't have the car in READY when trying to read codes. You will still get power to the code reader when you plug it in to the car because the OBD port is always powered. But it must be in READY to read any codes.
  8. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I always use the Battery-Saving function on my fobs when not in use...
    PriusChat won't let me upload a screenshot right now, but Page 178 of my 2017 Owner's Manual explains how to disable the fob battery.
  9. BiomedO1
    1,474
    796
    SacTown, Ca
    Here you go:
    The other way is to place your FOB in a Faraday bag. I highly recommend this - you do need to close the bag to prevent signals from going up and out of the bag.
    Hope this helps....
  10. Washingtonian
    Washingtonian Senior Member
    716
    617
    I found it on page 736 of my 217 Owner's Manual. It actually says that your fob can be turned off, but the dealer has to do it for you. I plan to be out of the country for a couple of months starting next month. Would it make sense for me to just remove the battery from the fob while I am gone?
    Ray
  11. RRxing
    2,520
    1,791
    NEPA
    I don't know why the Prime is different (having to get the dealer to disable it), but in your case, yes, I would remove the fob battery. For long-term storage, look up T-SB-0037-20, Long-Term Vehicle Storage Guidelines (since file uploads aren't working yet.)
  12. PianoBench
    PianoBench Member
    145
    91
    San Francisco
    I would get a second OBD II scanner and try again. It sounds as if the car drives just fine after a jump start.
    #12 PianoBench, Feb 6, 2024
  13. Trollbait
    11,560
    I thought any electrolyte checking and topping off was suppose to be done with a fully charged battery.
  14. BiomedO1
    1,474
    796
    SacTown, Ca
    ideally, but if you let the electrolyte level get below the plates - I was told that portion of the plate is irrecoverable, even after topping-off. Don't know if that's true or not; because I never let my lead-acid batteries get that low.
  15. Trollbait
    11,560
    I know the electrolyte density, thus the level, changes with charge state. Top it off before charging, and it can over flow when charged. That results in the electrolyte concentration being off in addition.
