Does mileage increase as the PIP gets used more?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SudeepHArya, May 1, 2014.
  1. SudeepHArya
    SudeepHArya Junior Member
    46
    Jackson, New Jersey
    2014 Prius Plug-in
    Has there been any reports of mileage increasing as the car gets used more? Meaning not from me learning how to drive the car better but as things get "broken in" & "more loose" is there an increase in mileage?
    I searched the forum initially and did not see a question posted like this. Thanks!
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Tires appear to have a break in period, each time you get new tires there is a drop then recovery.
    In part this is because a worn tire is a smaller tire so it reports you are driving longer than a new tire would.
    51,160
    i never saw any noticeable improvement, although, there are some that would say so.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    After my PiP data got reset, I did notice less MPG. After a few drives, the car learned and adjusted to my driving I guess, and the MPG went back to normal.
  5. SudeepHArya
    46
    Jackson, New Jersey
    2014 Prius Plug-in
    Hi how much does the B-Quiet Ultimate ultimate help with sound deadening and did it cause any mileage drop?
  6. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Engines have a break in period too. Gasoline engine efficiency should increase after about 2000 miles.
  7. bisco
    51,160
    sound deadening makes an amazing difference, and mpg drop is not noticeable. probably less than 1 mpg.
    SudeepHArya likes this.
