does my prius have one?
Discussion in 'Gen 2 Prius Audio and Electronics' started by jrod81, Mar 5, 2007.
  1. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    we are looking to buy a 2005 prius used. do all of the cars have the aux input for ipods? where exactly is this located?
  2. westofrome
    westofrome New Member
    39
    No, they were added beginning with 2006.
    However, there are various aftermarket options for adding an aux input, mostly via the changer port.
  3. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(jrod81 @ Mar 5 2007, 12:58 PM) [snapback]400530[/snapback]</div>
    Nope, it's a 2006+ feature.
    Also, there's a difference between the generic AUX Input and the iPod connection.
    2006+ cars have the AUX Input. The iPod connector is extra.
    I have a 2005 and I added DICE's iPod connector which comes with both AUX and iPod connection for a pretty good deal here at the PC shop. The other more expensive alternative is VAIS' unit.
  4. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 5 2007, 09:12 PM) [snapback]400654[/snapback]</div>
    Our 2007 with package no. 1 has an aux input jack in the storage compartment under the center armrest. For about $10.00 I bought a cable at Radio Shack with a male connector on both ends. Pluged one end into the aux input and the other end into my ipod nano. It works perfectly.
    Warren
  5. luckyboy
    luckyboy Member
    204
    29
    <div class='quotetop'>QUOTE(westofrome @ Mar 5 2007, 04:10 PM) [snapback]400535[/snapback]</div>
    also a base 2006/2007 (with no option packages) will not have the AUX input
  6. jrod81
    jrod81 Member
    161
    Fayetteville, AR
    so the DICE does work on the 2005? cool.
    <div class='quotetop'>QUOTE(Tideland Prius @ Mar 5 2007, 11:12 PM) [snapback]400654[/snapback]</div>
  7. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(jrod81 @ Mar 6 2007, 11:05 AM) [snapback]401025[/snapback]</div>
    It does on mine. I have the JBL system though. It should work with the base audio unit but double check with those who have the base audio unit.
