Does OEM Nav HU have anti-theft code?
Discussion in 'Gen 3 Prius Audio and Electronics' started by rleepac, Jan 24, 2011.
  1. rleepac
    rleepac New Member
    44
    Manteca, California
    Husband is getting ready to disconnect battery to install a few things and the instructions say to get the code from the stereo if it's an anti-theft type otherwise it won't work when he re-connects the battery.
    Does the OEM Nav HU have this anti-theft code? If so, how do I find it?
    Thanks in advance!
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    You should have received a card with the code on it when you purchased the vehicle. Idealy, it should be kept in a secure location, but chances are, it's in the binder with your owner's manual! Good luck!
  3. rleepac
    rleepac New Member
    44
    Manteca, California
    No card :( I've scoured the owners manual, the binder with all the manuals, the glove box, all other compartments, and nothing about an anti-theft stereo code. I guess I'll call the dealer and see if they can help me.
    Thanks!
  4. Tideland Prius
    16,158
    You mean like Honda? Not that I know of. Paul58, I have not heard of such a card.
  5. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If the equipment is OEM, there should be no anti-theft codes. You will have to reset the radio station settings and your auto-up on the driver's side window.
  6. Mendel Leisk
    38,732
    Just for insurance, hook up a trickle charger before disconnecting the battery. I used a cheapy 0.5 amp charger (labelled as a motorcyle battery charger) for a recent battery swap, all memories were retained. You can get 9 volt devices described specifically as memory savers, but they may or may not be up for the job.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I didn't get one of those. Could post a scan / picture?
  8. homegameroom
    homegameroom New Member
    37
    Cleveland, OH
    I disconnected my battery terminal (negative side) to install the illuminated door sills last week; the factory Nav was fine, other than it seemed to do a software reload when I turned everything back on. No worries, unless yours has been replaced. Of course, YMMV.
  9. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    Thanks for this information! I had the same question. Moving from an HCHII to the Prius, the Honda had a 5-digit code you had to enter each time the power was off.
  10. rleepac
    rleepac New Member
    44
    Manteca, California
    Great! Thanks for the quick replies.
    We're gonna go with "no code required" and see what happens.
  11. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Um, that basically defeats the purpose of disconnecting the battery. The whole point is to make sure that the electronics (including things like the airbags) are powered down to avoid damage or injury. Hooking up a charger to keep the system powered up is no different than leaving the battery connected.
    I wouldn't worry about the code - many people here have had their 12V batteries die :)) including me!), and the radio still works afterwards.
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Toyota doesn't use this type of system in the Prius HUs.
