Does plugging in to Apple carplay also charge your phone ?
Discussion in 'Prime Main Forum (2017-2022)' started by bluespruce, Feb 9, 2021.
  1. bluespruce
    bluespruce Member
    79
    72
    New England
    2020 Prius Prime
    I know it does on other cars but the prime also has a battery charging button so I was wondering if that is needed to be on.
  2. Mendel Leisk
    41,493
  3. schja01
    schja01 Senior Member
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    Since I don’t know what you are referring to I’d say no it doesn’t.
  4. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Mine does
  5. Db17
    Db17 Member
    188
    92
    Visalia, CA
    When I use carplay i get a funny icon not like the regular one that shows battery charge and signal strength. Instead i get an icon that is a cellphone with a slash through it. Wonder what that means?
  6. Tideland Prius
    16,559
    It means you can't use your phone (because the car's system is accessing it).
    I guess it's an updated icon to the old text that says "unplug accessory before using iPod" (or something to that effect) when I plug in my iPod.
    Db17 likes this.
  7. mrchowmein
    mrchowmein Member
    73
    56
    San Francisco, California
    2020 Prius Prime
    When you plug in your iPhone via the USB port to use carplay, your iPhone will charge. The charge button on the center console is for the wireless phone charger. You cannot use both at the same time. Both operate independently. So to answer you question. You do not need to press the button on the center console to charge your phone if its already plugged in.
    Hicksite, Sarge, Db17 and 1 other person like this.
  8. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Why the 2021 Prime doesn't have wireless CarPlay is beyond me....
    pghyndman likes this.
  9. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    There are adapters for just north of $100 that will give you wireless apple carplay.
    pakitt likes this.
  10. pakitt
    2,173
    1,313
    Colorado
    I checked with Amazon and found only 2 vendors: Vapeart and Carlinkit. Are these the ones you were referring to, or did you have other brands in mind or other online stores I can get such an adapter?
  11. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    Yes but I don’t have firsthand experience.
  12. Graz
    Graz Member
    179
    28
    JOYEAUTO CarPlay Wireless Adapter AI Box Add Android 9.0 Multimedia System to Factory Radio, Option Remote Control Support Wireless CarPlay Google Play Split Screen Mirroring Navigation(4+32GB)
    There ya go
    Via Prius Chat for Android
    Graz '21- Midnight Black Metallic Ltd.
    5/28/2021
    Graz '05 - Tideland Pearl - Package 6
    02/02/2005 - ???
    231,776 miles of smiles
    Lifetime: ~48.71 MPG Highest Tank: ~57.9 MPG Highest Miles/Tank: ~559
    P185/65R-15 Bridgestone Ecopia EP422 SL 42.0/40.0 psi
    OPTIMA Yellow-Top 12 Volt ACC Battery
    XChanged the Traction Battery at 184K
    Limit your funding of international terrorism!
