Does Premium Drive/Brake more smoothly than Plus
Discussion in 'Prime Main Forum (2017-2022)' started by pbh8, Sep 24, 2017.
  1. pbh8
    pbh8 New Member
    United States
    I took a test drive of a Prius Prime Premium last week and absolutely loved the car. But I don't like the Softex seats or the large infotainment screen, so this week I tried the Plus trim. It might all be in my head, but I felt like the ride in the Premium was smoother and that braking was a lot easier with the Premium too. In looking at the differences between the two trims, it didn't seem like there should have been a big difference in how the car drives. Has anyone else had a similar experience? Any theories on why my driving experience might have been different? Thanks!
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    It's all in your head. ;)
    While I don't know for sure, I think it is highly unlikely that is any mechanical differences with the different "trim levels".
    But it is possible that one of the new vehicles you drove had an initial defect making it drive differently.
    One of the test cars might have had low tire pressure, etc.
    Do the tests again, maybe at a different dealer.........and make sure that your route is the same.
    pilotgrrl likes this.
  3. ct89
    ct89 Active Member
    323
    266
    New England
    Also make sure they are both charged-up and you are comparing EV driving to EV driving...I'm becoming increasingly drunk on EV mode...I really prefer the feel/handling of electric.
    pilotgrrl and Krzysiek_KTA like this.
    49,507
    only thing i can think of is different tyres and pressures?
    pilotgrrl and Kramah313 like this.
  5. Mark57
    2,945
    2,736
    OK
    I was thinking the same thing. I prefer the feel of EV.
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The larger wheels will give a different "feel". Some say better, some say worse. ;) They are heavier and should feel "rougher", though some will say "more planted".
  7. ct89
    ct89 Active Member
    323
    266
    New England
    Larger wheels? Is there a difference between the trim levels? I though the size (195/65/15) and rims were the same across the levels.
  8. bisco
    49,507
    me too.(n)
  9. Tideland Prius
    16,159
    Wheel size is the same for all Prime models. It's possible some members are thinking you're talking about the Gen 4.
    It shouldn't matter (we're not aware of any differences between the Plus models and the two higher trim levels). They should all be configured the same way (same suspension setup, same or similar tires and same braking configuration).
    Was the Plus a test drive vehicle while the Premium was a new vehicle? Maybe the test drive vehicle was driven harder so the ECU has adjusted that way.
    Another possibility is the mode you're in (though it shouldn't affect the ride). ECO, normal or PWR mode will change the accelerator sensitivity.
  10. David Beale
    5,963
    1,981
    Edmonton Alberta
    A fully charged battery makes the car heavier so it rides smoother. ;)
    pilotgrrl and jtv like this.
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    David......I think Bisco has hacked your account !!! :ROFLMAO:
  12. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    To me this is the most likely reason. Not saying they did this, but it's easy to imagine as I tighten my tinfoil hat setting up the tires on the higher price model to ride better. Kind of like at electronics stores where they use better connections for higher priced TVs and monitors to make them look better as people pass by.
    pilotgrrl and bisco like this.
