Does Prime Hit Parking Stops?
Discussion in 'Prime Main Forum (2017-2022)' started by keithjam, Dec 14, 2016.
  1. keithjam
    keithjam New Member
    Hollywood, FL
    Is the Prius Prime so low to the ground that it hits parking stops? You know, the triangle thing that stops a car when parking. Drives me nuts when designers make the car so low that the bumper rubs everything.
    Tyfly and Prodigyplace like this.
  2. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    My Gen 3 hits them, so I would expect the Prime to as well. I try not to park over them just in case they hit.
    Coast Cruiser likes this.
  3. Mendel Leisk
    41,605
    With our gen 3 it typically doesn't hit wheel stops, but will often scrape on curbs, have to be careful. The bear is: you can scrape over a curb, then the trailing edge of the underbody plastic hooks; when you back off it lifts and tears some bits. I've done a repair already had one point that was pretty chewed.
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    You mean it can detect all kinds of things around it but not a curb?
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'm sure it detects them just fine, and notifies the owner with a loud "bang" when you get too close to one.
    jaqueh, Nic Steussy, ruby and 6 others like this.
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    :ROFLMAO: :ROFLMAO: :ROFLMAO:
    It all depends on how high the parking block/stop is. I noticed that some are higher than others, and I've come very close to running into them. I try to remind myself to never park where there is a parking block, and/or I will back into the spot.
  7. Mendel Leisk
    41,605
    My son encountered one wheel stop: one of the rebar "nails" that secure it to the ground was protruding about 5 *^$!$ inches. Tore things up good. :mad:
  8. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    keithjam, this bugs me as well. Why can't we standardize maximum curb height and minimum vehicle ground clearance such that the curb isn't hit?
  9. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Can sombody of you new Prime owners measure how much minimal and maximum space the front and rear bumper have left to the ground ?
    The 2016 Prius only has 12.2 cm minimal ground clearence according to the german specs, but it seems to me that the front and rear bumper do have a bit more .
    Apparently the Prime has the same ground clearence as the liftback.
    #9 civicdriver06, Dec 14, 2016
  10. Lee Jay
    5,850
    4,036
    I believe that's "cm" not "mm".
  11. civicdriver06
    797
    324
    Germany
    Of course ! :D
  12. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  13. Duanerh
    Duanerh Junior Member
    Prime clearance is 4.8 inches, less than previous models. I have rubbed one curb and been fine on others. Tire stops haven't been a problem.
  14. civicdriver06
    797
    324
    Germany
    Yes that's the minimall ground clearence,but I believe it has a higher clearence at the front and rear bumber as they are angled upwards a bit .
  15. MikeDee
    1,580
    597
    What about opening the passenger doors and hitting the curb?
  16. Coast Cruiser
    2,267
    2,571
    On my car, it's the lower front fascia(?) or the aerodynamic front panel underneath the car that scrapes when I'm going down a driveway. Or if I hit a parking block.
  17. civicdriver06
    797
    324
    Germany
    Just watched the 2016 Prius Prius-Chat Walkthrough Video .
    The front bumper of the 2016 has 6.1 inches ground clearence.
    If the Prime has the same or not extremely worse it should be okay !
  18. Coast Cruiser
    2,267
    2,571
    I would sure like to know where that 6.1 inches is??? :LOL: Mine scrapes just about every time I go down my own driveway, and it scrapes going up the driveway at the post office, and it's grapes going out of most shopping centers.... Maybe I'm just too fat. :ROFLMAO:
  19. bisco
    52,057
    step away from the pizza...
  20. Coast Cruiser
    2,267
    2,571
    :( :cry:
