Does Prius needs Power Steering Fluid?
Discussion in 'Gen 2 Prius Technical Discussion' started by AllenZ, Nov 29, 2011.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I can't find the fluid tank under hood.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Your Prius uses electrons to move the steering. The tank for those is in the back under the hatch.
    In other words, no, your Prius does not need power steering fluid.
    Tom
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    No, it has drive-by-wire (electric steering wheel). It is maintenance free so there is one less thing to worry about.
  4. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I would be worried if it were truely drive (steer) by wire. It has mechanical steering like every other production car except the Prius has an electric assist instead of the more common hydraulic assist.
  5. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Come to think of it, I think you are right.
  6. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Throttle is drive by wire, but the brakes and steering are mechanical with traditional hydraulic brake assist and electric power steering.
  7. qbee42
    18,058
    3,074
    Northern Michigan
    Mostly right. Throttle is drive by wire. Brakes are brake by wire but have a fail-back safety system that reverts to hydraulic. In normal operation there is no hydraulic connection from the driver's foot to the brakes, so it is truly brake by wire. It is not traditional hydraulic brake assist. Steering is mechanically coupled with electrical boost.
    As a minor point of clarification, the power brakes are driven by an electrically powered hydraulic pump.
    Tom
  8. AllenZ
    640
    63
    Chicago
    Great info. Thank you all!
