Does Prius Prime automatically silence phone?
Discussion in 'Prime Main Forum (2017-2022)' started by draheim, Nov 3, 2018.
  1. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    I've spent more time than I'd have liked troubleshooting this issue with Apple over the last couple days, and it turns out it might not be my phone but my car.
    IOS 12.1 on my iPhone 7 has a feature called "Do Not Disturb While Driving." I have it set to "activate manually" because I actually want to receive email notifications and, if I'm not using the Toyota on-board navigation system, I also want to be able to get audible navigation directions via my iPhone. However, when I start driving in my Prime all audio shuts off--even the clicking on the keyboard when texting (at stoplights of course). It will play sound when sitting still in my garage, but as soon as I pull out and start driving everything on my phone goes silent. I still can get phone and text alerts via the Bluetooth connection in the car, but the actual phone goes silent.
    I've gone as far today as completely reinstalling everything on my iPhone, and it still did the same thing in my Prime. Then I just tested my phone in my wife's Subaru and the iPhone works the way it's supposed to--it provides audible directions in navigation, plays a tone when a new email comes in etc.
    So, it seems it's my car causing this problem.
    Is there a feature in the Prime that forces the phone to turn off the audio? I did a quick search (both here and Google, as well as the Prime owner's manual) and couldn't find anything. For now I am puzzled, so hopefully someone else has experienced something similar and can help me out. Thanks.
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    That sounds like it's working the way it's supposed to actually as it's doing the same thing my iPhone X is doing. Audible on the phone while sitting, but once it's on the move all audio goes to the car via Bluetooth. I drive a Prius "C", not a Prime however. But I will say my Windows phone worked the same way while in the car.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,034
    Westminster, Colorado
    My Android phone has the option to play audio through Bluetooth or not. I have it set to not except for music, and all the audio comes from the phone.
  4. schja01
    schja01 Senior Member
    1,827
    1,218
    Chicagoland
    2024 Prius
    Limited AWD-e
    Check your iPhone's "AirPlay" setting after connecting to the Prime's Bluetooth there should be an option to direct audio to the Phone, Speaker, Bluetooth, HandsFree. It's not a sticky so next time you connect you'll probably need to set it again.
  5. My first EV
    My first EV Junior Member
    38
    16
    2018 Prius Prime
    First of all texting even when you are sitting waiting for red light to change is a “distracted driving violation” in Canada! Good luck in Seattle.
    That “Do not disturb while driving” is nonsense! When someone call you while you’re driving, you can choose to answer or not! And that’s the good thing now almost all cars have blue-tooth hands free for your cellphones. But I’d like to “know” who is calling me, if I can peep their caller ID ( if they have it). Then I can choose to pull over if I need to response. If you’re so incline not to use the cell while driving, might as well lock it in the trunk evertime you drive!
    So, disable that “ do not disturb while driving” function and keep sounds of your cell goes normal again, good luck!
  6. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    Thanks all. I actually thought I had set this thread to send me email notifications when I got replies, and I didn't get any notifications, so I'm glad to see there are some responses in here to chew on. This is the first time I've checked back on this thread since posting it.
    I've done my own bit of research throughout the week, along with working with both Apple and Toyota on this question. So yes, when in the car Bluetooth basically takes over the audio functions of my phone. To disable it from doing this you can either (1) manually change the settings in Bluetooth (on the car menu) to see your phone as a phone, audio player, or both (default is both, and it seems you have to select this every time you get in the car) or (2) switch off Bluetooth on the phone entirely. You can also set your audio source as Bluetooth, which then plays all the sounds that would come through your phone on your car instead. But then you can't listen to radio or a separate MP3 player (I still use a Zune, and love it). So that's not an option.
    With Bluetooth turned on (on my phone), I get text message alerts and phone calls through the car. That's fine, and useful. But there are also settings for email notifications in the car menu, and I do not get those. I've walked through all possible settings with both Apple and Toyota--even changed my email software on my phone from Outlook to the default Apple email app--and nothing works. All I really want at this point is to know I have gotten new emails while I am driving, especially work-related emails that I might need to reply to. Toyota ended up giving up and telling me to talk to my dealership. They said it's possible that depending on exactly what kind of phone I have, service provider, etc., the email notification function may not even work on my car. I've also read some things while searching that this is not even possible, and that Toyota left the email settings in the software almost by mistake or something (or maybe because they might bring it back sometime). It would be very helpful to know that something is not meant to work rather than something is not working the way it's supposed to.
    So ... long story short: Do any of you get email notifications while in your cars?
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Actually yes. But my Prius is a "C" and not a Prime. It got so annoying that I entered the radio's settings and turned off notifications for email. (Junk email was overwhelming) Not sure if it matters, but I'm using an IPhone X
  8. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    That’s understandable. But I’d assume if I could get it to work the way I’d want it to (perhaps a generous assumption) I could control from my phone which email account(s) I got notifications from and when. In my case that would dramatically reduce the number of junk messages for which I’d receive notifications via the car. As it is, it appears I have no option to get any.
