Does Prius Prime trunk fit a baby stroller?
Discussion in 'Prime Main Forum (2017-2022)' started by Sophie C, Nov 26, 2018.
  1. Sophie C
    Sophie C New Member
    Bay Are
    2019 Prius Prime
    We are planning to start a family and also want to get a plug in hybrid. We've noted ample evidence that the Prius Prime fits carseats in the backseat, but can't find any info on whether you can also fit a stroller in the trunk or not. Anyone out there know/have experience? Thanks!
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Strollers come in different sizes.
    Umbrella Stroller: No Problem as long as it's collapsible. You probably can lay it across
    the floor in front of the rear seats and not use any trunk space with no rear passengers
    with long legs.
    Full size Stroller probably not unless you can fold down one of the rear seats.
  3. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I would not recommend a Prime for carrying kids and stroller since there's only 2 back seats and not much cargo room if you want to see out the rear window. There are better alternatives out there: Clarity plugin, Pacifica hybrid, even regular Prius. I have attached pics of what a medium stroller (Chicco Liteway Plus) looks like in the back. It does take up a lot of room and raises the privacy cover a little.
  4. Mendel Leisk
    41,908
    You've got the 2019 Prime (shown in your avatar), or you're just considering it?
  5. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    I take my kid's graco stroller easily (with room for other items) in my PiP. I detach the front tray of the stroller to fit it more conveniently. Thus, I can confirm that PiP handles the Baby Strollers and even reasonable rear Baby seat space (both rear faced or front faced baby seat).
  6. Diemaster
    Diemaster Active Member
    295
    262
    so. cal
    it will fit my moms wheelchair.
  7. bisco
    52,393
    prime hatch deck is 3" higher than pip.
    best to take the stroller to a dealer and check it out yourself. we have a pretty decent size stroller for our grandson, and i think it would fit.
    schja01 likes this.
  8. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    This is not the car for family with stroller. You need a SUV.
