Does Prius use "drive by wire" for accelerator pedal?
Discussion in 'Gen 3 Prius Main Forum' started by Chris2128, Apr 1, 2011.
  1. Chris2128
    Chris2128 New Member
    85
    Oklahoma
    Just want to know your thoughts, if gen III and/or gen II has it or is it just plain hard wire like most cars?
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Yes, its a drive by wire accelerator setup on both the Gen II and Gen III
    Most cars nowadays have a drive by wire system.
  3. 2maples49
    2maples49 Junior Member
    64
    Salem, OR
    It is not a mechanical cable.
    It is not a radio signal.
    It is an electric signal sent through a physical electrical wire.
    Pretty cool, I think. Thanks, Dan
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I remember when I was younger and the vette had it because it saved weight, I thought it was cool. Nice to see tech which was once unique making its way to so many more daily drivers.
  5. SW03ES
    2,480
    176
    Gaithersburg, MD
    Yep...thats how a drive by wire throttle system works. Been around since the 90s. Commonplace today.
  6. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Yes, I think amost all cars and trucks is gas by wire now.
  7. Chris2128
    85
    Oklahoma
    So that's how the pcs works ! It voids the pedal signal (in danger) and sends signals to the warning system and then brakes eventually. But is it true that someone on pc said it's better to leave the pedal and not apply brakes??
  8. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    That's how most of the new airliners do it also. For awhile it was thought to have cause a British Airways jet to land short of the runway in London, the pilots pushed the throttles up for more thrust but no action from the engines and plane landed in the grass short of the runway, but I believe it turned out to be an icing problem with one of the sensors in both engines.
  9. donee
    donee New Member
    2,956
    198
    Chicagoland
    Many cars are drive by wire.
    This is probably how Honda Accords get such good highway fuel economy, the possibity of modifying the transmission ratio, valve timing and trottle, independant of the drivers foot, when a period of steady speed driving occurs is possible with drive-by-wire.
    When they had those congresional hearings, they were comparing the GM and the Toyota systems for drive by wire. So, I imagine there are plenty of GM cars that are drive by wire too.
    It wont be long before your comment "like most cars" will be wrong, if its not already....
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I've been hearing this for a long time but does someone know a reputable source for this (e.g. reputable car magazine, NHTSA, IIHS, etc.)? I recall even reading an article about how this made for easier assembly by automakers. Unfortunately, my Google-fu isn't good enough. :/
    BTW, you mentioned an 02 Infiniti in one of your earlier posts. What model was it? It very likely also used "drive by wire" for the accelerator. My 02 Nissan Maxima did. How do I know this? I had a recall relating to the accelerator pedal stopper (piece of plastic on the bolted to the floor to limit pedal's travel).
    I believe the 02 model year was the first model year Maxima to use a drive by wire accelerator system.
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Article from November 2009 in the LA Times: Data point to Toyota's throttles, not floor mats - latimes.com
    If every Toyota uses it, I would say it is safe to say almost every other major manufacturer also uses said system.
  12. fuzzy1
    10,602
    While off topic, the suspected icing was in the fuel system. [ame="http://en.wikipedia.org/wiki/British_Airways_Flight_38"]British Airways Flight 38.[/ame]
  13. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    If you own a Prius and you have a question like the one in the topic why not just look at the pedal and see if it is connected to a cable or a wire?
    The answer is very easy to find out.
  14. Chris2128
    85
    Oklahoma
    Dear cwerdna, you had asked what Infiniti I had, it was 02 q45 with laser cruise control , which I hated!! It never worked more than a couple hours. I always ended up stopping at every 4th or 5th gas station on the highway and cleaning the sensor to be able to use cruise control at all. This was I think a "fail" idea from Infiniti And lexus, that didn't work too well, but again this was a breakthrough back in 2001. It never work in sunlight, fog, or when road was wet, I had it replaced twice because of small stones hitting them. It wouldnt let me choose even manual cruise !! I'm glad I sold that car!
    That's why I had asked earlier that in Prius we should be able to select normal cruise just in case something happened to the radar! But it is very sturdy , I used it for my 36 hour drive . At least every 3 to 4 hours continuous on interstate, stopping for gas and again 3 to 4 hours use. I'm impressed with how well the drcc works with my Prius.
    And btw, my 2000 BMW 328i also had "drive by wire" because the dealership had to replace when my car gave me trouble. It was so scary like something happened to my engine like not being able to breathe!!
  15. 413X3
    413X3 New Member
    36
    CA
    The Corvette Z06 had an electric clutch, that was tough to learn how to find the sweet spot.
  16. SW03ES
    2,480
    176
    Gaithersburg, MD
    The laser cruise on the LS430 works fine as long as its not raining...
    The radar cruise was a big upgrade though.
  17. Chris2128
    85
    Oklahoma
    Dear judgeless,
    "Houston we have a problem!!" why is the top of your pedal showing wires? I looked at mine today and it has a plastic looking pipe going up all the way! That's weird.
  18. Judgeless
    1,821
    257
    Cleveland, OH
    That is how mine came stock. It is a GenIII 2010 IV
  19. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    What is the knob on the left side of accelerator mount. It looks like you could rotate it. Maybe it's an accelerator sensitivity adjustment? I noticed this knob the other day when I was exploring under my Prius dash.
  20. ETC(SS)
    7,350
    The Prius does indeed have a FBW throttle, but you may not be able to tell just by looking at the accelerator pedal.
    In this picture, and hypothetically, there could be a throttle cable exiting through the firewall that's concealed by the black enclosure, and the electrical plug could be connected to something like a throttle position sensor.
    To answer your question with another question:
    Isn't a forum a proper place to ask questions?
    When I used to drive a podium I always used to tell trainees that the only stupid question is the one that you don't ask....:cool:
