Does Techstream work with WiFi OBDII connector
Discussion in 'Gen 2 Prius Technical Discussion' started by whburling, Apr 29, 2016.
  1. whburling
    whburling Junior Member
    53
    17
    Gales Ferry, Ct
    Does anyone have any experience with a WiFi connection to an OBDII plug as opposed to a USB connection to the OBDII plug.
    I do know this:
    * wifi is established between devices (not between software). ie: the obdii connector and the laptop that I am using.
    * Techstream software is written independent of devices it is connected to.
    * Drivers connect the TEchstream software to the hardware (such as USB etc). Currently, for Techstream operating on Windows (any version), Microsoft provides the Drivers for Techstream data to be placed on the USB bus.
    So the question boils down to whether drivers for WiFi know where to fetch the commands issued by Techstream and know where to place the data once it is fetched from the CAN bus (located in the car).
    (please...no guessing....)
    #1 whburling, Apr 29, 2016
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    In order: No. Yes.
  3. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    the key would be the protocol the adapter supported vs what your car's protocol uses.
    Bluetooth vs USB has no bearing on CAN, K-Line, ISO, etc. Those define the structure of the data which is converted by the adapter into a USB or Bluetooth signal.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Whether it works or not, there are a couple other issues to consider.
    1. Is the system on the laptop a supported version of Window$? Mine is running XP, so I keep the wifi turned off to provide an air gap against viruses.
    2. If wifi is on, Techstream will want to call home and will soon ask you to provide the authentication key.
  5. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Both of you are posting on a thread that’s 3years old
  6. bisco
    51,155
    you too :p whoops, and me :oops:
  7. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Lol
  8. jerrymildred
    11,517
    14,137
    Tampa, FL
    We have threads here that are way older than this one and still active and pertinent. :)
