Does the C have an engine oil monitor?
Discussion in 'Prius c Main Forum' started by Oldwolf, Mar 30, 2012.
  1. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    Does the C have an oil life monitor or is it like my Gen II where a light comes on at the appropriate time telling me to change my oil? Couldn't find anything about this in the C manual I downloaded. Thx.
  2. formula
    formula Member
    320
    32
    CA
    I guess there is a maintenance light that will come on?
  3. Oldwolf
    825
    110
    NC
    2016 Prius v wagon
    That would be nice I guess but I couldn't find a reference to that fact in the owners manual.
  4. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    The regular 2010 Prius liftback has a maintenance warning at 5000 miles (I don't remember reading anything about it in the manual at the time either). It's probably safe to say that the c has a similar feature.
  5. kkim
    kkim Active Member
    386
    132
    kauai, hawaii
    Have you checked in the separate maintenance schedule booklet?
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    all toyota's that i know of have a main't req'd light..
    it's nothing more than a mileage counter to remind you when to change your oil..
    that's the light you're pretty much looking for.
  7. Oldwolf
    825
    110
    NC
    2016 Prius v wagon
    Yes, but I don't find it mentioned in the manual.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    The owners manual discusses resetting the maintenance light on P. 349.
    Since there are little pissant things to do every 5000 miles, like rotate tires, it is not clear to me if it comes on every 5K for those, or every 10K for the oil.
  9. SquallLHeart
    826
    247
    San Jose, CA
    the light starts flashing at 4500 miles from its prior reset.. as an indication that the upcoming oil change is needed..
    then after it hits the 5000 mile mark, it stays on.
    3 people like this.
  10. Oldwolf
    825
    110
    NC
    2016 Prius v wagon
    I thought the recommended oci was 10 k on the C??
  11. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Yes, 10K for oil changes, but apparently the light comes on every 5K for tire rotation etc.
  12. SquallLHeart
    826
    247
    San Jose, CA
    though the maintenance recommends the oil changes to be 10K instead of 5K.. if you look carefully, it still does suggest changing it every 5K if the vehicle is driven in harsher conditions.
    specifically..
    "Repeated trips of less than five miles in
    temperatures below 32°F / 0°C"
    and
    "Extensive idling and/or low speed driving
    for a long distance such as police, taxi or
    door-to-door delivery use"
    but otherwise... yea.. 10K is fine.
  13. vinnie97
    1,430
    277
    Somewhere out there
    hmm, need a quantification for "low speed driving." ;-) (under 30 mph?)
  14. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    "Low speed" for me is under 25 mph, but I don't know how Toyota defines it. Still, this is strange, since drivers don't normally cruise below 25 mph for long distances.
