Does the cabin air filter really filters out anything?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qbui, Jul 19, 2010.
  1. qbui
    qbui Junior Member
    16
    Los Angeles
    I'm sure this has been asked before but hopefully no one will get upset with this thread for asking again. I don't know if the cabin air filter really filters out anything but maybe fine particles. It does not really filter out exhaust fumes in my opinion. If I'm stuck behind a polluter, it's like I'm sucking the tailpipe of that car/truck. Maybe the factory filter doesn't do as good a job as others but I didn't notice this bad of an exhaust fume problem with my old BMW and I didn't change the cabin filter on that car for the last 50K+ miles that I had it after the maintenance expired.
    Does anyone have a recommendation for filtering out exhaust fumes on a 2010 Prius other than not being behind a polluter? I thought the Prius didn't have a cabin air filter until I read it on PriusChat.
    Thanks!
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Many cars (including BMWs) have a system that automatically turns on the cabin air recirculation feature when it senses pollution in the outside air. The Prius doesn't have this system, so if you get behind an old smoker, you need to manually turn on the cabin air recirculation.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    It's a dust and pollen filter. Fumes will make it through.
  4. Kennewick Man
    Kennewick Man Junior Member
    42
    Kennewick,Wa.
    X2.............:eek:
  5. Martin37
    Martin37 New Member
    200
    23
    Joseph, Oregon
    Unfortunately mice and/or pack rats will make it through too! :(
  6. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    It won't remove those nasty smells of manure. The plasmacutter in the IV and V are supposed to help reduce odors, but the jury is still out on that one.
    The filter does remove a lot of dust and other stuff like hair and crap from the air. Every time ive changed out in-cabin filters in my old cars, they've always been saturated with junk.
  7. tf4624
    tf4624 Active Member
    526
    51
    Get the AN version from Japan from Sigma auto
    the one in the car is a peice of s**t
  8. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    It is a particle filter but if you have it engaged before you approach the odorous offender it should not infiltrate the cabin since the filter works in re-circulate mode. Additionally since it is re-circulating it will continually reduce allergens like pollen and mold spores to very low levels.
  9. tonymtdew
    tonymtdew New Member
    York, PA
    In one of my previous cars, 2003 Hyundai Elantra, it would get soot like particles built up near the vents. It drove me nuts.
    My current car is a 2005 Saab 9-3 and I never had any problem since it had a cabin filter.
    I am waiting for my 2010 prius to get delivered (any day now) and I can assure you that having the filter does filter out a ton of crap that my elantra never did. It was quite disgusting!
  10. bisco
    49,488
    you made me take a look at my wife's 08 hycam. after 34,000 miles, it filtered out a ton of grayish black stuff and tree debris. thanks!
  11. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    My Prius at 11K miles already had a junked cabin filter
  12. rctech
    rctech Junior Member
    46
    Chicago
    If you want to filter out smells and other VOCs, you need an activated carbon filter. They dont work 100% on the first pass, but in re-circ mode, smells do go away pretty quick. I had a honeywell charcoal prefilter that I cut into a filter-sized rectangle, and then put it under the standard air-filter.
  13. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  14. cossie1600
    898
    92
    CT
    My cabin filter was coated with leaves and it was completely black, not sure if it was washable
  15. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    When I tried cleaning my cabin filter with compressed air, I could get all of the larger debris but not the smaller black particles. The local parts store did not have a replacement for the 2010 Prius so I tried washing mine even though the manual says not to do so.
    The washing cleaned off the black particles but at first I thought I had ruined the paper filter. After leaving it in the sun to dry, it dried nicely and seems to be working fine. I plan to pull it this weekend, check and change it out now that the parts store is now carrying the replacement.
