Does the eco model back windshield bother anyone?
Discussion in 'Gen 4 Prius Main Forum' started by inferno, Mar 5, 2016.
  1. inferno
    inferno Senior Member
    1,072
    405
    Since there is no wiper in the back, how does it perform in snow and rain. Can you live without the wiper? With the gen 3 that window below the fun is always dry... But the back windshield always bothered me with rain and I can't see things clearly in my rear view mirror!
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Sedans don't have a rear window wiper and people just deal with it. Shouldn't be too big of a deal.
    JohnF likes this.
  3. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I too would like to know what folks that used to have a Prius with a rear wiper and upgraded to an Eco without a wiper feel. Snow and rain...?
    Thanks all
  4. vince22
    vince22 Active Member
    205
    249
    califorinia
    We are having heavy rain right now in the bay area, no problems here with my Eco, I have Lexus SUV's with rear wipers I have not used them in years.
  5. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Excellent point!
    I had a Gen 3 for 5 years. In rain I often didn't bother to use the rear wiper. In a light mist, it could get annoying because the wiper blade would skitter across the glass and make noise if not enough water had accumulated on the glass between swipes. This could happen even when the wiper was set on "interval".
    In snow, as long as I brushed off the snow before driving it was usually fine, especially if I turned on the rear window heater. I suppose in very heavy snow it might be useful.
    I wonder if there is some way to turn on the backup camera while moving forward????
    Climate change may obviate all of this. Very little snow in the NE this winter.
  6. inferno
    1,072
    405
    Sedans come without it? I guess I haven't checked sedans lately! Does the volt 2 go without it?
  7. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    The back window stays surprisingly clean as you motor along. Both the top section and he bottom section.
    If there is any utility to the wiper, to my way of thinking it is at startup to get the beads of water that have collected. The window cleaned by the wiper, is relatively small, however.
    As an aside, the front window has very well defined channels along rather side of it. Not sure why they were engineered into the design, but they might help direct the aIr flow over the back and help keep it clean.
  8. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    It looks like the Chevy Volt doesn't have it either, I'm guessing for the same reason the eco doesn't, weight savings.
    This is the first car I've ever owned with a rear windshield wiper and I could definitely do without it. Rear defrost really takes care of snow as long as you clean off any snow first before getting into the car.
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Forget about snow. The rear wiper just piles it up on the spoiler on Pearl S. Doesn't take long before you can't see over the pile.
    Who watches behind? You've already passed those idiots! ;)
  10. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    No, those idiots are passing me. That's why they are idiots. And because they are idiots, I try to keep a wary eye on them.
    Seriously, though, I like to know if there is any traffic behind me. If not, I drive whatever speed I want. If there is someone behind me, I try to go at least as fast as the speed limit on 2-lane secondary roads.
  11. Trollbait
    12,666
    Sedans have even more sloped rear windows than they had in the past, and get by fine without a wiper there.
    I never turned the rear wiper on, and left it on. One swipe was usually good miles.
    The rear wiper is more important on wagons, hatches, and SUVs with a vertical back end. Moisture, along with dirt, accumulate faster because of the poor aerodynamics. That shouldn't be a big problem on the Prius.
  12. bwilson4web
    16,352
    Rain-X.
    Prius Pete likes this.
  13. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    This is true and the stuff really does work in the rain.
    I guess I should have asked or seen if anyone has experience with early morning dew that can coat a vehicle in some areas. Ie. not a full on rain and not snow..With the ECO is the rear window defroster with no wiper enough to clear off the morning dew and a light mist? Do the aerodynamics really clean off the rear window by way of the wind taking care of such along with the defroster?
    I'm thinking something like this:
    Thanks..
    #13 Blizzard_Persona, Mar 6, 2016
