Does the Gen III have passive alarm?
Discussion in 'Gen 3 Prius Technical Discussion' started by Basildane, Aug 17, 2009.
  1. Basildane
    Basildane Junior Member
    46
    My Gen II had a very basic alarm. The horn sounded if you opened a locked door without using the FOB.
    I cannot find any reference to this simple feature in the Gen III.
    Does it still exist, or is mine not programmed correctly, or what?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Which Gen III do you have? Some package information would be helpful.
    Tom
  3. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    I have a IV and it only has an engine immobilizer; no alarm that I can tell.
  4. Basildane
    46
    I forgot to mention. Its a model V, with Nav.
  5. jay_man2
    1,246
    143
    Manassas, VA
    I don't see an alarm mentioned anywhere on the Toyota site for the Prius, other than as an add-on accessory. I'm sure if it was offered as a factory option it would be called out like it is for the Highlander Hybrid.
  6. Basildane
    46
    Thanks for checking.
    Its odd that gen II had it standard, and its a no brainer, doesn't cost toyota anything, its just software.
    I wonder why they took it away.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    On the Gen III, they removed the alarm you referenced for the Gen II. It only has an immobilizer, but you can get the alarm installed (at port or dealer) which also includes a glass break sensor.
  8. Basildane
    46
    Makes sense. They probably lost sales on the optional alarm system, the built in one was good enough for me.
  9. Tideland Prius
    16,072
    a title is a little misleading if I must be honest. Passive alarm refers to the alarm system being armed regardless of the state of the door locks. IOW, it will arm the car after 30 seconds of the last door to be closed (independent of the doors being locked).
    What you're referring to is a standard alarm feature.
