Does the New Prius (LE) require an Old School Key?
Discussion in 'Gen 5 Prius Main Forum' started by priusmouse, Dec 17, 2022.
  1. priusmouse
    priusmouse Member
    244
    83
    Long Island, NY
    2023 Prius
    I was going through the details, having planned on getting an LE, and noticed that the remote key system is not available on the LE trim.
    “Smart Key System on front doors and trunk with Push Button Start, remote keyless entry system with lock, unlock and panic functions”
    This system specifically it says is NOT an option for the LE
    does this mean I will have to manually push a button on the remote every time I want to unlock the vehicle? Or does it mean that there will not BE a remote? What’s the deal here? Also, will the car not automatically lock after I walk away if I get the LE?
  2. Hammersmith
    Hammersmith Senior Member
    1,301
    1,322
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is a guess and only a guess, but I wonder if the LE has everything except the trunk keyless sensor like previous base-grade versions.
  3. FuelMiser
    FuelMiser Senior Member
    1,293
    883
    Monument, CO
    I have not gone through the specs on the 23 models, but I cannot imagine Toyota would eliminate this option altogether. What is more likely is that there is a 1-door SKS (Smart Key System) on the base trim and a 3-door SKS option on the higher trims as in Gen 3 and 4.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    896
    500
    Cow-lee-fornia
    2023 Prius
    If you go back and look at the videos of the interior you'll see that its still push button start. So still a wireless keyfob, just no smart key function on any doors on the LE.
    daisy555 likes this.
  5. bisco
    49,359
    this is a mistake, and a glaring omission in the specs on toyotas part. hopefully they will correct it soon
  6. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    If this helps, the newest Sienna LE has an old school remote, no SKS, yet push-button start.
  7. bisco
    49,359
    my base model 2008 only had the drivers door sks. after having the 3 door on my 2004, it was a real eye opener.
    i thought i wouldn't care, but having to fish out the fob every time i wanted to open the hatch was a real pita
  8. bisco
    49,359
    it the LE has no door SKS at all, that would be a deal breaker for me. then i would have to look at the next level up, and weight the cost/benefit. might make me give it a pass.
    #8 bisco, Dec 17, 2022
  9. Mendel Leisk
    38,635
    Yeah I guess it’s been thus since gen 2. So with 5th gen in the States, if you want a spare, no touch-to-lock/unlock. And in Canada, if you want a spare, you’re SOL.
    It’s the old wack-a-mole game, with the-boxes-I-want-ticked list.
    moonmist likes this.
  10. priusmouse
    priusmouse Member
    244
    83
    Long Island, NY
    2023 Prius
    Eh what does the smart key mean? Do you mean you have to pay extra to be able to keep the fob in your pocket and have the driver door open automatically when you are close?
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
    The elimination of the physical mechanical key on the steering column is a both an economic and a logistical move. The labor and design cost of mechanical assembly and the inventory of OEM and replacement parts has been eliminated.
    The mechanical key will eventually disappear from cars as has the mechanical shifter linkage and the mechanical parking brake.
    Mechanical keys and linkages require additional labor to assemble and are difficult to implement with digital electronic switching.
  12. fsu23phd
    fsu23phd Active Member
    185
    114
    Wilmington, NC
    I know that with the Rav4 Hybrid, the LX actually uses an old school key (slightly better than old school, since it is a switchblade that hides back into the FOB, thus not cutting up your pants pocket).
    I rented a LX Camery (non hybrid) about a month ago that had an old school key too.
    It seems like generally, on other Toyota models, LE has a key and XLE and above do not. I cannot say if this remains the case in the Prius, but based on the description of the trims, XLE indicates push button start and LE does not, just like the Rav4 Hybrid and the Camery descriptions. I have not been able to see any LX review videos so I can't say for sure, but I am suspicious that the LX model includes a physical key. The trim comparison description that does not indicate "push button start" is the biggest clue.
    I am also shopping for a Kia Sportage Hybrid. They have a similar story, with the LX using a physical key, and the EX and above using push button start.
  13. Trollbait
    11,494
    The Camry LE still has a key, though it and the remote fob are one piece.
    Yes, the smart key is the system that lets you open and start the car without taking the key out of your pocket.
    We don't know what the Prius LE has. It could be an old school key and remote for the locks, or a smart key that only works with the driver's door. We just know the higher trims have the smart key for the hatch and other doors.
    Do you own Hondas?
  14. priusmouse
    priusmouse Member
    244
    83
    Long Island, NY
    2023 Prius
    ugh hope it is just smart key for one door rather than 3. If it is that, does that mean that you can still access the trunk once you have come close to the driver door? Currently I think mine only has it for the driver door, I got to the driver door, open the door and Im 99% sure I can open the trunk after without doing anything else. Would that be how it works? What incant do is walk directly to my trunk when it is locked and just open if with the fob in my pocket.
    man if they take this away it might be enough to make me reconsider the Bolt. Forcing me to pay for the XLE makes the prius not worth the fuel savings imo. At that price you shiuld consider the prime. But that is so expensive, why not just go all electric for less and still get a smart key etc?
    Trollbait likes this.
  15. Trollbait
    11,494
    The 3 doors are the driver, front passenger, and hatch.
    Unlocking the driver on a 1 door system should unlock all the doors. Or not. That is likely one of those settings you can change, like whether the doors lock when the car moves. Those details will be in the owner's manual.
  16. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    The opening of the driver's door on most all cars are programmed at the factory to open just that door for the sake of safety for the driver. The driver has then to use the switch on the door to open the other doors. The ECU has to be reprogrammed to open all four doors and the hatch with Techstream. That's how my 2012 Prius v came. I had to re-program it with Techstream to open all four doors.
  17. Mendel Leisk
    38,635
    There is info in the Owner's Manual, that may be applicable. See attached excerpt, from North American 2010 Prius (hatchback) Owner's Manual:.
  18. Trollbait
    11,494
    The manual will have a list of what is customizable, and whether it can be done by through the car or requires a dealer/techstream.
    I was able to change if all the doors unlocked with the driver's just through car settings in the Sonic.
  19. Hammersmith
    1,301
    1,322
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I just looked that up a bit ago and now I'm feeling really stupid. I've been complaining about having to pull out my key fob to open the passenger door or hatch for over a decade.
  20. daisy555
    daisy555 Senior Member
    1,379
    579
    CT
    Yes and once you’re used to SK regular key feels archaic.
