Does the plug in give off any toxic fumes?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priusenvious1, Apr 13, 2016.
  1. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    Just wondering since I am planning to make a man-cave out of my garage and I plan on hanging out there, is there any harmful fumes after the electric charge runs out? If I park in the garage and then just start hanging out there, I want to make sure I'm not breathing anything toxic in.
  2. mrbigh
    3,686
    699
    Long Island, NY
    If you leave in LA, I feel sorry for you.breathing the common air................................
    52,694
    when you say, after the charge runs out, do you mean to leave the car in ready?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  5. priusenvious1
    325
    37
    LA
    I mean if I am no longer running on the charge and running on hybrid instead, does the car give off fumes?
  6. mrbigh
    3,686
    699
    Long Island, NY
    If the engine (ICE) will run, of course !!!!
    Kramah313 likes this.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yes, virtually all engines make Carbon Monoxide. Do NOT leave any car running in a living space.
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    This reminds me of Arnold Schwarzengger's recent claim that internal combustion engines (ICE) are bad for society because you cannot live in an enclosed garage with one running. I want to stick him in the nearest coal plant, which ain't too far from here.
    A warmed up and properly operating Prius, will make very little CO. But if the room is totally enclosed you will deplete the oxygen and also fill the room with CO2. Eventually without adequate oxygen in the air, perhaps the Prius would start making Carbon monoxide. Note my garage has so many air leaks, I suspect I could get away with it. But you need adequate ventilation, if the car is running.
    As far as trace contaminants you have the 12v battery and the Li battery neither of which is expected to be a problem.
    At the same time recently, Schwarzenegger also said fossil fuels kill 7 million people annually and therefore are intolerable. But the 7 million he is talking about are the poor folks in China/India burning wood, dung, and coal in their houses without ventilation. I told my daughter that is the worst dis-information I've ever heard from a (former) elected official. But I do not think it was intentional disinformation, he just doesn't understand at all.
    #8 wjtracy, Apr 13, 2016
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yes, the same toxic fumes that is emitted from any other internal combustion engine will come out the tail pipe when there is no charge left.
  10. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I recall detecting toxic fumes from my garaged plugin Prius only once!
    Its was after a spirited drive back from picking up some tacos and beer :)
    On a more serious note, no toxic fumes while parked (turned off) or charging.
  11. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    The bigger risk, and this is for ALL vehicles not just plug-ins, is fire which sometimes seems to happen when the cars are just sitting there. So fire alarm in garage is probably a good idea.
  12. bisco
    52,694
    why would you want your car running while you're in your man cave?
    KV1955 likes this.
