Does the Prius battery discharge rule apply to cell phone batteries?
Discussion in 'Gen 2 Prius Main Forum' started by Amyshubby, May 18, 2006.
  1. Amyshubby
    Amyshubby 2017 Prius Prime Advanced
    94
    28
    Long Island, NY
    Just wondering. I had a Verizon LG 6600 that I used for about an hour of talk per day. I would talk until the battery was almost dead, then recharge it. After about a year (a year and two weeks to be exact- 2 weeks out of warranty) the battery stopped taking a charge.
    I have subsequently switched to a Verizon Razor phone. I'm considering charging it every time the battery goes down to one bar so it never gets lower then (for arguments sake) 33%. This is (pretty much) the method Prius uses to extend the life of the battery. Do you think it would work with a cell phone?
  2. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I never let my battery go too low. My phones last well over the 2 years and my current one shows no signs of having difficulty either. I usually just finally decide to upgrade.
  3. darelldd
    6,057
    389
    Northern CA
    The biggest damage you're likely to do with a cell phone battery is charge it too much, from what I've seen. The bottom line is the phone chargers are quite dumb, and don't care how long your battery lasts. They could be made smarter for a few more cents, but what incentive does the phone maker have to protect your battery when they could be selling you a new one? Current cell phone batteries last on average of about two years regardles of how you treat them, so my advice is to just charge them in the way that is most convenient for you, and plan on needing new ones in two or three years.
    EVs and the Prius take great pains to protect the battery. You can't buy a new one for $25! We have 10-year-old Rav4EVs on the road with over 160k miles on them... with about 2% loss in capacity! And these are charge-depletion vehicles, unlike the Prius. Quite a bit different from the cell phone experience, eh?
  4. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(darelldd @ May 17 2006, 11:27 PM) [snapback]257374[/snapback]</div>
    Right on the money.
    Charge your phone whenever you want to. Just unplug the thing when it says it's full.
  5. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Additonally, litium ion batteries have a shelf life, whether you use them or not. Oxidation inside the battery eventually degrades it's capacity. This aging begins at manufacuring time, regardless as to whether the battery is used or not.
    The shelf life is around 1 and 1/2 to 2 years (at least for the notebook batteries I've read about). And like I said, it starts at manufacturing time, not first use. You've had your phone for just over a year, but the battery is probably a couple of months older than that. Still seems a little bit short, but it's approaching the self life.
  6. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(Marlin @ May 18 2006, 08:47 AM) [snapback]257419[/snapback]</div>
    I sure hope the new lithium Prius batteries manage to last longer than that.
    Maybe it's 'planned obsolescence' that kills current batteries, and Toyota's plan is for a longer run...
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Nickel Metal Hydride and Lithium Ion batteries do not exhibit a memory effect, so you can recharge them anytime. I recharge mine after use, and keep them topped off. Nickel Cadmium batteries do exhibit a memory effect, so they need to be completely discharged periodically. Lead-Acid batteries should not be deeply discharged, and should be kept fully charged.
    The new battery charging chips do a good job not over-charging, so you should be able to leave a phone plugged in. If you have an old charger, or a crappy phone, then you need to unplug it when it is charged.
    Never charge a battery with the wrong type of charger. Not only can you ruin the battery, but there is a risk of fire and explosion.
    On that note, there are a lot of counterfeit battery packs on the market these days. They are made to fit phones, cameras, and other high-volume consumer items, but they are not made to the same specs as the OEM battery packs. There have been a number of fires and explosions associated with these cheap knock-off battery packs. The problem has become so wide spread that many of the new charger chips feature systems to validate genuine battery packs and refuse to charge phony ones.
    Tom
  8. NuShrike
    NuShrike Active Member
    1,378
    I've had my SE t637 for about 2 years now. I try to avoid going into the "red" zone, and the battery is going pretty strong still (albiet, seems to hold less charge).
    I have a charger at home and in the car to keep it topped off especially since the Prius BT drains the life out of the celphone.
  9. finally_got_one
    finally_got_one New Member
    151
    Orange County, California
    <div class='quotetop'>QUOTE(Amyshubby @ May 17 2006, 10:35 PM) [snapback]257360[/snapback]</div>
    Having had laptops and cellphones (I have a RAZR also), I agree with the other posters. Dont overcharge; the chargers are not smart and will not shut down when they detect the battery is full. I recharge my phone when I get down to 25% charge and am careful not to overcharge (company phone...if I overcharge and battery goes out, I pay for the cost of a new battery!) ;)
  10. aaf709
    3,862
    2022 Prius Prime
