Does the Prius C have an air filter for the fuel system?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Phil 29 Palms CA, Oct 21, 2013.
  1. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    My old car used to have an air filter that was located on top of the carborator. I assume the Prius C has a fuel injection system. Is there an air filter with this kind of fuel system? If so, where do I look under the hood to find it? How often should it be replaced?
    52,352
    there should be a squarish black box with clasps on the sides. the filter is inside. check your owners manual.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    clips to get to ^ the air filter, just past ^ orange frame member
  4. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    This information can be found in your owners manual, complete with drawings and descriptions.
    In the photo presented, the box directly to the right of the yellow ring (oil level dip stick) contains the air filter. There are easily removable clips holding it down in the front, and tabs that go into holes in the back
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    All cars have air filters. At least if they want to keep running they do.
    Mr Incredible likes this.
  6. flotowngtm
    flotowngtm Junior Member
    42
    22
    You should probably just take your car to the dealership, or any service shop.
  7. Phil 29 Palms CA
    119
    44
    Thank you for answering my questions. The thread posted "The box to the right of the yellow ring dip stick" allowed me to find the air filter easily.
  8. Mr Incredible
    955
    506
    Neb
    Hey! POST # 1776. Congratulations, you are a patriot.
    'Merica.
    ztanos likes this.
  9. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Change it every 30k miles or earlier or when necessary.
  10. Phil 29 Palms CA
    119
    44
    Thanks for the advice - 82FINITY!
