Does the Prius C have an EGR circuit or not?
Discussion in 'Prius c Main Forum' started by farmecologist, Jan 14, 2020.
  1. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    Hi all,
    After searching around a bit on PriusChat, I can't seem to find a definitive answer on whether or not the Prius C has an EGR circuit. It seems like most discussions follow the "I haven't heard of any EGR problems with the prius C" line of reasoning. That got me thinking of the Prius C actually *has* an EGR circuit. Looking at a few engine bay pics, I can't see one ( full disclosure..I didn't look all the close (y) ). I also know that the engine in the Prius C is simlilar to the Gen 2 Prius.
    So what is it fellow internet sleuths? Does the Prius C have an EGR circuit or not?
    Thanks in advance! (y)
  2. farmecologist
    1,958
    1,799
    Southern MN
    #2 farmecologist, Jan 14, 2020
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Good to answer to own question;).
    I wonder if @bobzchemist ever sold his misorder:whistle:?
    He might be able see if there are subtle differences for comparison(y).
    SFO and farmecologist like this.
  4. farmecologist
    1,958
    1,799
    Southern MN
    At any rate, it certainly appears like the Prius C has easier EGR access than the Gen3.
  5. Mendel Leisk
    41,590
    I don't think anyone's ever cobbled together a "repair manual" pdf, for the c? Or v for that matter. :(
    farmecologist and Raytheeagle like this.
  6. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Our resident librarian hasn't:whistle:?
    Something to work on in your free time:).
    It would save the garage queen from more prodding anyway(y).
    farmecologist and Mendel Leisk like this.
  7. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    Yeah, i actually highly doubt that there are any reports about clogged Prius C EGR. Same for oil consumption.
  8. PriusII&C
    PriusII&C Active Member
    426
    144
    San Jose, California
    So what's the verdict? Does C need a EGR cleaning?
  9. farmecologist
    1,958
    1,799
    Southern MN
    Nothing definitive. However, the Prius c does have an EGR circuit ( see above ). Unfortunately, it seems nobody here has done a cleaning or has even checked the EGR for clogging, etc...I think we need some c owners to check it so we can get some more data.
    That could be because there are vastly fewer Prius c's in existence ( at least in areas that would post here ). It could also be due to EGR positioning and/or where the EGR circuit taps the exhaust. Like I said though...we need some owners to actually check their vehicles, etc...(y)
    BTW - here is another thread I started regarding the EGR and head gasket :
    Any cases of Prius c EGR clogging and/or head gasket issues? | PriusChat
    #9 farmecologist, Jan 29, 2021
  10. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I don't mean to be rude, but why do this?. EGR clogging isn't an issue with the Prius C. Heck, you don't even drive one, so why care?
  11. PriusII&C
    426
    144
    I guess the reason is that we are not sure if it is no issue or unknown issue. @farmecologist is concerned that his PriusV may behave similarly with the C.
    I do have a 2012 Prius C with about 110k miles. But I am NOT familiar with the EGR system, so don't want to mess with it unless there is a Youtube for me to follow.
  12. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Yes, we're sure. There is not an issue with the EGR system on a Prius C. I've spent YEARS of my life working in GM/Toyota dealership. It's not an issue....
    SFO likes this.
  13. PriusII&C
    426
    144
    @dubit Good to know, so we don't need to worry about cleaning the Prius C EGR system. Care to elaborate why it is an issue for Prius but not for Prius C?
    SFO likes this.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Not the same design.
    And I think that it is not a problem on all regular Prius models either.......and people sometimes think it is a bigger deal than it really IS.
  15. PriusII&C
    426
    144
    @sam spade 2 I thought it was a big deal because many Prius got head gasket blown due to EGR clogging. Maybe I get that wrong?
  16. ChapmanF
    18,272
    There does seem to be reported an unusual incidence of head gasket problems in Gen 3.
    And it does seem that many Gen 3 owners check their EGR systems and find them clogged.
    And there is a vigorously thriving PriusChat cottage industry of claiming that causality is established between those two things.
    The claims toss around various supposed explanations of the supposed causal relationship, such as an always vague "gets hotter", and the cottage industry never gets any more industrious about how any of those supposed explanations could be tested, or what would constitute evidence for or against them, or even trying to put the various different supposed explanations into some kind of order by plausibility, or even acknowledging that it's kind of weird not to do any of that.
    So we perennially stay right where we started: head gasket failures and EGR clogging seem to be two things that can happen to Gen 3s.
    I don't see anything about the EGR system in the c that suggests a different design, other than fitting in the components above the engine rather than off to the side.
    RobAustin likes this.
  17. PriusII&C
    426
    144
    I wonder if both the EGR clogging and head gasket blown are related to excessive oil consumption in Gen 3: The clogged oil rings in Gen 3 induce higher oil burning and blow-by. The higher blow-by brings more oil via the PCV route to the cylinders and further increases oil burning. This excessive oil burning contributes to the EGR clogging, which in turn causes higher cylinder temperature and results in head gasket blown.
  18. ChapmanF
    18,272
    Yeah, you're not the first to the party, that's one of the speculative chains of causality that have been endlessly spun around here as a way of taking two things observed to happen and claim to know more than that. Nobody ever steps up to do any of the homework that could start backing it up, say, just starting at the end of the chain working backward, the first two necessary questions would be:
    - blowing a head gasket due to cylinder temperature requires temperature of at least ... ?
    - EGR clogging makes ... ? difference in cylinder temperature
    Nobody wants to be distracted by details like that. So we have 9,453,272 posts all saying "yep, it's X leading to Y causing Z meaning hotter meaning head gasket" and zero posts that show effort to find out if it's true or not.
    PriusII&C likes this.
  19. sam spade 2
    7,035
    2,803
    2017 Prius c
    It depends on your definition of "many".
    The problems seem to occur only or mostly with only one of the various engine designs.
    And the mileage usually is very high.
    And there are a lot MORE still on the road that do not have that problem.
    And finally, I don't think that anyone has any good proof that a "clogged" EGR loop is the cause of head gasket failures.
    If you know how an engine works, that theory really doesn't make much sense.
  20. PriusII&C
    426
    144
    @sam spade 2 "If you know how an engine works, that theory really doesn't make much sense." Care to elaborate?
