Does the Prius overheat in hot traffic?
Discussion in 'Gen 2 Prius Technical Discussion' started by ZC1, Jun 9, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Let's say you're on asphalt, 90-100 outdoor temp, but 70 percent or higher humidity, you also have the AC going full blast and cars are creeping 10ft every 10 minutes kinda thing.
    Will the Prius overheat?
    Since it doesn't have an engine temp gauge, I can't tell if she's too hot, any way to tell?
    ZC1
  2. Bob64
    1,540
    92
    Virginia
    nope it wont... unless your blocking your grill.
  3. Patrick Wong
    18,200
    6,472
    This is a scenario where the Prius shines. The engine should only run as needed to keep the traction battery SOC at two red bars. Hence there is little chance for the engine to overheat in traffic.
  4. viking31
    viking31 Member
    515
    22
    West Central Florida
    No, the Prius does not overheat in traffic. Not even close. Cars for decades have gone very thorough testing of nearly every conceivable type of driving condition anyone would normally put a car through. I have not heard of any modern automobile (say within the last twenty years) overheating in stop and go traffic during a very hot day with all the accessories running.
    Rick
    #4 2006
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    no. i just did that a half hour ago.
    the engine is only cycling on and off to power the a/c compressor, not to provide forward momentum. it's not a concern.
  6. icarus
    icarus Senior Member
    4,884
    976
    earth
    $150 scan gauge will tell you. I also think there must me an overheat check engine light.
    But as said before, it's not something I would worry about. A bigger problem is staying warm at 0f in stop and go traffic.
    Icarus
  7. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I was driving here in Phoenix today and it showed 108... 106 on city streets (freeway is always a bit warmer with all the cars/asphalt). Anyway, I was on a conference call on my hand free and pulled into a car wash. I probably sat in the parking lot for 30 minutes with the A/C blasting away while I finished up the call. I was pulled into the parking slot up to a half wall so I'm sure the heat was just radiating off that wall. :)
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    "Summer time, and the livin' is easy.." Oh yeah, says who?
    ZC1,
    Yesterday, I ran a test that, until better real life experience comes along,
    satisfies my only-somewhat scientific mind that the Prius will not overheat
    in conditions very similar to what you have posed.
    Ballamer, Merlin is suffering through an unseasonable early-summer heat
    wave right now. Temps on Saturday, 100 deg. F; on Sunday, 97 deg F; and
    today, 100 deg F. Same expected through this weekend. Yesterday, while we
    were out doing the weekend errand drive-about, I decided to see what would
    happen if I left the car in Ready-Park with the AC on for an extended period.
    Temp was 97 deg F, humidity >90%, car was stationary, in the open, direct
    sun, no breeze, AC set to 78 deg, second to the lowest fan setting, not Auto,
    started test with 5 blue bars.
    AC kept running continuously on HV battery until it was in 2 purple/pink bars
    for a while, coolant temp showed 184 deg F on the --> ScanGauge. <-- Then
    ICE kicked in; 1184 RPMs, IGN (ignition advance) 13, ran for 2 minutes, HV
    battery built up to 3 blue bars, coolant temp rose to 196 deg F. -- MPG of
    course dropped, ~1/2 MPG during the 2 minutes. AC on the whole time.
    ICE then shut off, AC continued running for 3 minutes as HV battery dropped
    back to 2 purple/pink bars. Coolant temps backed off to 184 deg F.
    I watched as the car went through this cycle three times, with only minor
    variations in the ICE on/off times and coolant high/low temps.
    I've read that the radiator fans come on at ~205 deg F. I was well below
    that. I feel confident that it would take conditions much hotter than I
    saw for the Prius to overheat in stop and go, creeping-slowly-along driving.
    Hope this helps set your mind at ease -- it did mine.
    Edit: Get a ScanGuage, it's best "mod" for your money, no doubt about it.
  9. ZC1
    711
    Metro Detroit
    Ask a clear question, get a clear answer.
    You guys are awesome!
    Tiny history why I asked:
    Had tubs of frozen foods (pizzas, burritos, etc in icey plastic tubs) in the back with the rear seats folded down and the AC blaring. At my in-laws, I left the car running in the driveway, since it was 90 and 75+ humidity (sweaty horrible) and was wondering if the car would overheat and die.
    Everytime I opened the door to check the food, it felt like a mini-reefer (if you know what that is).
    Thanks again.
    ZC1
  10. ZC1
    711
    Metro Detroit
    I see everyone of your hints to buy the scangauge.
    I'm a technical guy, without a doubt, but I bought some protection items for the Prius prior to getting the scangauge.
    It's next on the list, without a doubt.
    Thanks for all the prodding.
    ZC1
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I haven't been able to get the fan to start WITH the grill blocked. I lost 2 pieces from the top so that is only 75% blocked and now that it is 100F I pulled both tubes from the bottom.
  12. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Jim, other than the engine, you might want to watch out for inverter temp. The radiator for the inverters are on the bottom. Electronics don't like to get hot. If I were you, I would unblock the bottom of radiators FIRST.
  13. sendconroymail
    sendconroymail One Mean SOB
    256
    Boy I hope not.... or my car would be overheating everday from early May until the end of September. :eek:
  14. patsparks
    10,664
    567
    Adelaide South Australia
    She does better than the old fashion cars.
    The fan on the AC condenser would move warm air out of the engine bay when stationary and the AC would be the only heat source most of the time.
  15. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    Interesting. I ran a similar test on Friday afternoon. Temp 85 F, Humidity "high", in shade, New Black 2008 Touring, parked with windows closed.
    My ICE ran for about 1 minute, then rested for 4 minutes. So total cycle time of 5 minutes was same as yours, but lower temps and shade made my ICE run only 1 minute instead of your two minutes.
  16. miltw
    miltw Junior Member
    MidAtlantic Coast
    The ICE runs only to charge the battery. The AC compressor is not a belt driven device ; like in the old days, but is powered direct from the battery.
  17. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I think he meant the ICE is indirectly powering the A/C by charging the battery.
    Anyway, the only references I've seen here to the Prius overheating is when there's something wrong -- defective fan, pump, or air not bled after a coolant change.
  18. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    Ira Gershwin :p
  19. JimN
    7,028
    1,116
    South Jersey
    The bottom was blocked 80% with the middle open. I do pull these tubes. The 8 top sections stayed blocked until I found 2 pieces missing.
  20. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I was thinking about this thread again today. I decided to hit Best Buy to buy a few things at lunch. I thought I was going to run right in and out so I left it running and locked up. It was 108 degrees. :) I then couldn't decide on which 2 cordless mouses I wanted to buy, and also were looking at a few other things. I probably ended up in there for 30 mins. I had the A/C as high as it would go the entire time. My car didn't catch fire... and everything seemed normal... and it wasn't stolen. :)
    Mike
