Does this look familiar? (please help)
Discussion in 'Gen 2 Prius Main Forum' started by AndyZaa, May 24, 2022.
  1. AndyZaa
    AndyZaa Junior Member
    35
    17
    New Brunswick, NJ
    I'm hoping a fellow Gen 2 owner can help - I'm 2000 miles from home. On my drive out here I started to hear a "creaky" noise when accelerating hard from a full stop. Once I'm up to speed or if I accelerate slowly there's no noise.
    Today I was able to jack the car up and have a look underneath. I don't see anything obvious, but as I was poking around I found this piece. It's 1-5/8" in circumference and about 1-1/2" high. It looks like half of a suspension part of some kind that broke at a weld on the top shown in the first photo. It is metal outside and inside with rubber in the middle. I found it laying loose right on top of the hole in the bracket of the third photo.
    I can't see where it came from. I'm going to jack up the car further to get a better perspective, and will look at some exploded diagrams. Meanwhile I'm hoping that a PriusChatter will recognize the part and point me in the right direction.
    Mamn thanks to anyone who could have a look and provide any guidance.
  2. dolj
    dolj Senior Member
    8,446
    4,290
    Wellington, New Zealand
    Possibly the resonance damper off the Insulator mount subassembly?
    Part Number 12305-21190.
    AndyZaa likes this.
  3. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    It's part of the lower motor mount. Couldn't tell you exactly what it does, probably a resonance damper like dolj said. I've seen a few break off and wedge themselves between the motor mount and the engine which will result in some weird creaking and clunking noises. The car is perfectly safe to drive without it but at some point you might want to get it replaced.
    #3 Texas Hybrid Batteries, May 25, 2022
    AndyZaa and Catherine Kourouklis like this.
  4. AndyZaa
    35
    17
    New Brunswick, NJ
    Thank you both so much - you are lifesavers! I wasn't looking forward to a 2000 mile drive home worrying all the way that I was going to have a breakdown. I spent hours today looking at the motor and tranny mounts and couldn't see anything missing. That piece is on the top side so I wasn't able to do anything but feel the area with my finger and it wasn't obvious. Your diagrams and photo make it crystal clear, and that spot you describe is exactly where it was sitting. I literally cannot thank you enough.
    ColoradoCrow likes this.
  5. dolj
    dolj Senior Member
    8,446
    4,290
    And yet literally you have. :D;)(y):whistle:
    AndyZaa likes this.
  6. AndyZaa
    35
    17
    New Brunswick, NJ
    Thanks again, @dolj and @Texas Hybrid Batteries! I arrived home without incident and just a little clunking. It was so much less stressful with your spot-on input and knowledge sharing. Now it's fixing time. My question is - is part #4 - 12305-21190 Insulator Mount Sub Assembly a one-piece replacement or can I source just the tuned damper piece (the cylinder). It looks like it bolts into the insulator assembly. And I'm guessing the damper cylinder broke at a weld as it looks like I have a half of it, broken at a weld (first photo is mine and second photo is a parts photo).
    Would you also replace the #1 - 1236A Center Rod while I'm in there? Are used parts eBay or otherwise OK (with due diligence) or would you only use new? I'm hoping to keep my 2006 for a while.
    Cheers,
    Andy
  7. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    #7 alftoy, Jun 13, 2022
    AndyZaa likes this.
  8. AndyZaa
    35
    17
    New Brunswick, NJ
    Thanks @alftoy, those are much better photos than I had. It looks like my piece isn't bolted but welded to the bracket, amd that is where it broke. I'll drill down on the part numbers and figure out which whole bracket to buy.
  9. alftoy
    1,132
    517
    They both look the same, but 010 is $31 and 030 is $90 from Toyota.
    AndyZaa likes this.
  10. alftoy
    1,132
    517
    #10 alftoy, Jun 14, 2022
    AndyZaa and ColoradoCrow like this.
  11. AndyZaa
    35
    17
    New Brunswick, NJ
    Thanks again @alftoy. I'm thinking of buying both parts new as they are wear parts and I don't want to cheap out and end up with another replacement down the road. Particularly the mount with the tuned damper on it as it looks like that part tends to break off at the weld, and I imagine used pieces may be on the way to a similar fate.
    I found these at https://parts.longotoyota.com/ using my VIN to match:
    Insulator, Product ID: 12305-21190, $206.78
    Center Rod, Product ID: 12363-21030, $84.34
    Do you folks have any favorite sites to buy new parts reliably?
  12. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,155
    1,776
    Mars Hotel
    AndyZaa likes this.
  13. dolj
    dolj Senior Member
    8,446
    4,290
  14. AndyZaa
    35
    17
    New Brunswick, NJ
    Thanks for the help, all! The dealer associated sites were about the same after factoring in shipping. I ended up buying from a local dealer through the official Toyota parts site with their free shipping promo - it was about $2 cheaper. I considered RockAuto and the various aftermarket options which were about half the cost but opted for the safer official parts. Looking forward to losing the clunks! PriusChat is a great community thanks to folks like you.
