Does this mechanic's assessment ring true to anyone?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ackey jo, Dec 28, 2023.
  1. ackey jo
    ackey jo New Member
    Nevada
    2013 Aqua
    L Eco
    Our 2013 Toyota Aqua only has 37,000 miles on it. We don't drive it that often, but if we didn't start it every few days it would die...One day though, we couldn't revive it, so we replaced the battery & started it up every night...but sometimes it wouldn't start, even though the battery was showing as full. We'd turn the key & it would just make this clicking sound...The mechanic said the hybrid battery was leaking, which caused electrical issues due to corrosion of the brake booster. He's quoting us $4000. We had to pay to have it towed to him, so I'm not too keen on getting a 2nd opinion, especially since there aren't many hybrid specialists where we live...I'm not sure how much we'd get for selling it, but that's a lot to spend on a car that old. We'd be really appreciative for any advice, because we're completely in the dark here...
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    1st: there are two batteries. There's the ordinary 12v battery that runs the dome light, starts up the dashboard and computers.
    Then there is the hybrid battery, which is the big one.
    The large hybrid battery is what starts the gas engine, but it should be understood that the engine won't start unless both batteries are good.
    The small 12v battery to boot the computers, then the large 144v hybrid traction battery that actually starts the engine just to write it a different way.
    This "corrosion of the brake booster" doesn't make much sense here. There is a brake booster, it can have problems, but it isn't anywhere near either of your batteries, so it's hard to figure out what your mechanic might have meant.
    It is reasonable to believe that both of your batteries are dead or dying. The hybrid battery is meant to last 8-12 years, and that typically skews on the low side in cars that see infrequent use. The 12v battery tends to be good for about 6 years, so you ought to be ready for your 3rd by now.
    A recap: I would expect a multi-thousand dollar quote for battery replacement, it plausibly is about the right time for that, and doing so would make that into a real cherry of a car. But I don't understand what (might be) going on with the brakes.
    49,488
    toyota aqua? is this a chatbot?
  4. ackey jo
    ackey jo New Member
    Nevada
    2013 Aqua
    L Eco
    Thank you so much for your help! That makes sense...& it definitely helps to know about the brake booster. We never had any problems with our brakes, so I think we'll stick with the battery replacement & go from there. The cheaper battery we replaced recently, but not the expensive one with the cells...Thanks again.
  5. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Adding: there is a considerable difference in quality (and sometimes warranty) when you get the hybrid traction battery from Toyota. They're the only source for proper new ones.
    Rebuilts are a bit sketchy, and lately they don't save much money vs. the real deal from Toyota.
  6. ackey jo
    ackey jo New Member
    Nevada
    2013 Aqua
    L Eco
    That makes sense...He got back saying:
    Hybrid Battery=$1,845 used
    Master cylinder assembly=$738 used
    Accumulator=$369 used
    Battery junction box=$148 used
    Battery ECU=$148 used
    Labor=$220
    grand total=$3468
    I strangely don't see anything about the brakes...but maybe one of those things is brakes related? Again we're totally in the dark here...
  7. ackey jo
    ackey jo New Member
    Nevada
    2013 Aqua
    L Eco
    Oh he just added: also the 12V battery installed would be: $178
  8. bisco
    49,488
    the master cylinder and the accumulator control the brakes
  9. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Prices r too low to turn a profit he's nuts
  10. BiomedO1
    BiomedO1 Senior Member
    1,474
    796
    SacTown, Ca
    All used parts with probably 10x the mileage of the original OP car on them. I'd take it to another shop, something doesn't "smell" right.
    I definitely wouldn't put a used traction battery into it at that price, when a brand new dealership traction pack is @ $1700. I've seen that price mentioned recently.
    Just my humble opinion......
    FWIW, you've got a parasitic electrical draw somewhere that needs to be tracked down and repaired - not just throw parts at the car and hope the problem goes away. Since it's not a daily driver, I'd look into trading it in for a simple gas car. Your not saving enough gas money to justify the car, and resale value on a car like that is very high for now.
    #10 BiomedO1, Jan 4, 2024
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    Isn't the Aqua identical to the Prius C? Just the Aqua was a Japanese market name?
    A 37k mile hybrid battery of that year is a diamond in the rough and would easily be repairable to provide many more years of service.
    If the car is not starting due to a P0AA6 (leakage) issue, that could easily just be one module needing replacement, or just a good cleaning to remove any electrolyte seepage.
  12. ColoradoBoo
    ColoradoBoo Senior Member
    963
    631
    Monument, Colorado USA
    Toyota Aqua? Must be a BOT...only has 4 posts.
    But if anyone has a hybrid they don't drive much, it's best to sell it....hybrids are NOT like ICE in that rarely being used is okay...it is not, those batteries need to be used and charged or they die an early death. If they need a vehicle for minimum use, best to get an ICE or and EV they can leave plugged in all the time....can't plug in a hybrid unless it's a Prime and, in that case, why spend all that extra money for non-use?? Makes no sense.
  13. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Yeah this seems fishy all around. I wouldn't want a used hybrid battery in the first place, and certainly not when it was so close to the price of a brand new one with full warranty.
    And used master cylinders and accumulators are really tricky in the first place. There are many different versions that do not interchange with each other, which makes it hard to source exactly the right one in used-but-not-used-up condition.
    I'd look for another shop.
