Does Toyota prius 2013 has a fan ( tensioner ) belt ?
Discussion in 'Gen 3 Prius Technical Discussion' started by MSF1344, Jun 26, 2020.
  1. MSF1344
    MSF1344 Junior Member
    61
    UK
    Active
    Hi , I am wondering , has my Toyota prius 3th gen 2013 model has any fan belt ? because the other day I opened the bonet to check the oil level and i was looking to check the belt condition but i could not see any belt on crankshaft pully and I could not see any alternator . does anybody know ?
  2. krstof
    krstof Junior Member
    Lexington KY
    No, there is no accessory belt on the 3rd gen Prius.
  3. MSF1344
    61
    UK
    Active
    Thanks for reply . so why there is a pully on crankshaft and how the A/C working without a belt ?
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    A/C is electric so that it can work when the petrol engine is not running.
    I'm not sure but the pulley is either there to provide balance (help the engine run smoother) or is there because the same engine is used in non hybrids where a belt is used. Bottom line. don't worry about belts in a 3rd gen Prius.
  5. ChapmanF
    18,242
    It's kind of both. They do need something to stick on that end of the crankshaft that will damp vibrations and make a good fit against the timing cover oil seal ... and it turns out they have a lot of parts around that meet those exact criteria, and they look like pulleys.
    Ed Beaty likes this.
