Does your steering wheel make a rubbing sound?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by calbear, Apr 6, 2012.
  1. calbear
    calbear Member
    180
    30
    SF Bay Area
    Often when I am turning the steering wheel, even a little it now seems, I hear a whooshing/rubbing sound and feel just a little bit of that rubbing. It feels/sounds like it's coming from the housing right behind the wheel itself, maybe where the shaft bearing is. Is this normal? Anyone else getting this too?
  2. UCBRUINS
    UCBRUINS Member
    96
    44
    LA
    No noise from mine. I would get it checked out.
  3. DavidA
    2,344
    1,820
    Chicago western burbs
    My 2010 level 5 does that in the heat of summer, and has since it was new. The rubbing stops when it gets colder.
  4. Godzuki
    Godzuki Active Member
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
    No rubbing on mine either calbear...
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Mine did it and a few repairs were attempted under warranty. In the end they removed some housing behind that cloth between the steering wheel and the dash. Not sure you'd want to do it as you can now get your fingers in when in the past you couldn't. But the noise was bugging me.
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    All cars I've driven have made a sound when the steering wheel is cranked all the way to the stop position, just back off a touch when you reach that point.
  7. calbear
    calbear Member
    180
    30
    SF Bay Area
    Thanks for the feedback so far. Erikon, it's not at the extremes of the travel, it starts even when just going off center. It's like the wheel is too close to the housing or something in the bearing is rubbing. But like GrumpyCabbie notes, the repair may be worse than the noise. I always worry about dealership mechanics monkeying around trying to solve something they know nothing about. I'd rather know from this group's expertise and experience what the issue/solution is and just bring it to them that way -- or just let it go if there's a greater risk in trying to solve it.
  8. Erikon
    819
    105
    Rochester, NY
    It's making you unhappy, it's under warranty, so have the dealer look at it. There shouldn't be any visible signs of any repair, that would just mean a terrible job done by the dealer! If they have a good reputation (check comments and ratings online), then go for it! If they are iffy, find a dealer with a good service dept. and take it there for the work. Good luck!
  9. calbear
    calbear Member
    180
    30
    SF Bay Area
    Yeah, I just generally have this fear about individual mechanics rooting around inside something that's factory-assembled and not intended to be messed with... It's not like changing brake pads. I would feel better if there was a TSB on this at least..
  10. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    On my C I have also have noise that sounds like its from the wheel rubbing in the column or maybe not? It does only happen sometimes and its minor so I don't think im worried about it.
