Dome light comes on by itself ?
Discussion in 'Gen 3 Prius Main Forum' started by ED9593, Mar 14, 2013.
  1. ED9593
    ED9593 Junior Member
    Enfield CT
    For the second time in two years I have come out and found my dome light on. Has anybody else had this happen to them?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The dome light will come on automatically if the car detects the FOB beside it. This is for security (you can see in the back of the car before getting in).
    I can't see any way it could come on for no reason, other than a faulty auto system or switch (perhaps a switch closes when the car cools off).
    Better figure out if it's a fault and get it fixed or you'll have a dead 12V battery soon!
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    I know the interior lights come on when I walk up to the car with the key fob in my pocket - is that what you're talking about? If you hadn't noticed it coming on you would think it had been on all the time.
  4. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    Mine comes on frequently after I pile into the driver seat and then hustle my heavy bookbag into the passenger seat.
    I figure that my bookbag maneuver is brushing against the protruding dome light switch, which is 'on' when pushed to the passenger side.
    This happens a couple times a month at least.
  5. ETC(SS)
    6,541
    You have a G3.
    As the others have pointed out it's probably the SKS (keyfob) activating the lights. It could also be a hatch or door not fully closed or an interior light was pressed on and not pressed back off.
    An open door (or hatch) will keep you from being able to lock the car. A lighted dome light might be the culprit. I've jabbed mine on while gathering stuff and things and forgotten to jab it back off before leaving and locking the car.
    Since the interior lights come on when you park and shut down....it's easy enough to do.
