Dome light, key fob, clock, no radio, VSC
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paul2102, Nov 4, 2018.
  1. Rick0757
    Rick0757 New Member
    Cleveland
    man I wish you could make a video and send it to me cause I have an 08 Prius doing the same thing. I’m trying to follow your directions but I’m more visual.
    #101 Rick0757, Oct 9, 2019
  2. Pietro_S
    Pietro_S Junior Member
    Sweden
    Active
    Have you taken apart your plastic part in front of the fuse box inside car on driver's side?
  3. Ross Rabelow
    Ross Rabelow Junior Member
    Great chat everyone. I just followed your instructions on my 2005, that I recently purchased, and all of the functions you mentioned came back to life (radio, dome lights, fob, etc.). Thank you!
    I have worked on over 100 Prius' installing reconditioned hybrid batteries, and now remember that many have had this issue, especially 2004s and 2005s. I actually thought that the fob had limited functionality in some models. This is a very common problem.
  4. Knightrider
    Knightrider Member
    142
    30
    Kansas City
    Glad to see this is helping people.
    I had almost given up - but was very happy to see its helped 04/05!
  5. PNWbluegen2
    PNWbluegen2 New Member
    Seattle
    I'm actually having a bit of trouble following these instructions to get dome light, radio, SKS fob back. Any chance you could give me a summary of what steps i should take?
    So far - I have checked dome fuse, it is good, but I get no voltage in the fuse's socket ( to ground).
  6. LegoManiac
    LegoManiac New Member
    Brooklyn
    This happened to me when I was trying to change the Dome light from the original halogen bulb to an LED.
    I swapped out the 15 AMP "Dome" fuse with the spare and the problem was solved.
Loading...
